Flat Spot at around 2400 RPM
  • Riv Would you send me the number for the tsb thanking you kindly Cheers Foxy
    • I just got mine fixed today much better
      • Had mine done today & so far a vast improvement. No hesitation at all on the roundabout where it always did before the upgrade.
        Thanks Riv.
        REV
        • Hi people, Had my trans done today and the difference is amazing Now when I put the foot down something actually happens straight away Cheers Foxy
          • Good to see REV, do you notice that the shifting pattern is completely different and the way it holds 4th a lot more?
            • does your cruise control now work in sports mode too?
              I was certain that cruise never worked in S. But now... it does
              2011 150series GXL
              • Originally posted by wooley View Post
                Cruise always worked in sport mode, I just used it for towing a camper for 1000kms
                [B]Steve[/B]
                • Originally posted by Riv39 View Post
                  Yes, in the couple of drives I've had since getting the upgrade yesterday I have noticed a difference in the shifting & more so the way it holds 4th a bit longer in lower speeds. But I am very happy with the results from the upgrade.
                  It just goes to show if you can deal with one service advisor it makes everything so much easier. When I first reported the hesitation & that I was concerned about it, the advisor that i normally deal with wasn't there that day & another advisor said that it was normal & not too worry about it as every thing was fine.
                  When I went back in armed with the tsb number, the advisor that I normally (try) & speak to was there and when I told him about the hesitation he said he was aware of an upgrade.
                  he looked it up & there it was. (surprise surprise) I didn't need the tsb number that you supplied Riv but, thanks very much for your effort & info sharing, this is what makes this forum the great one that it is.
                  REV
                  • Originally posted by REV View Post
                    REV
                    I think thats because I was in there the day before you REV armed with the same thing. Hey REV is your rig Dark Furnace in colour with a pradopoint sticker on the back window?
                    • Certainly is. That would be a spot.
                      • No problem at all guys, the forum is great and I'm sure it has contributed to a number of improvements through members efforts.
                        I must confess that I believe the upgrade has led to slightly worse fuel economy but I still prefer the new shift pattern and no flat spot. I am going to start driving in S mode again for a comparison as I believe it does not hold 4th as much. I'll report back on my findings.
                        Wooley, I used S mode all the time before the upgrade an cruise worked fine for me.
                          I must just be on crack then. maybe it did work and I just thought it wouldn't.
                          and I agree, the fuel economy is definitely worse.
                          2011 150series GXL
                            We often cross paths on Woolcock street/Bruce highway near the new harley shop thats getting built heading into town. Mines a stock standard silver GXL with personalised plates. Well it wont be stock soon
                              Only city driving has suffered IMO, open road as per before.
                              • Hi Riv,
                                Sorry to be a pain, but could I troubke you for the TSB as well. We have ours booked in for the 30k service and the flatspot drives us mad! Thankyou.
