Had an incident where the oil filter was not screwed on tight after a general service. Car drove 3.2 klm and pumped out at least 6 litres of the sump. I didn't get an oil light 'til the last seconds of driving and pulled over and shut down immediately. Unfortunately I was in the process of accelerating to 100 kph as the speed limit had changed. Turbo is damaged but trying to ascertain if the engine may have survived.
Wondering if anyone can either describe or point me to a diagram that shows oil flow. Does it go from sump pickup to pump to oil filter then to lubrication channels or is the oil filter the last in the sequence. It will make a difference in trying to determine the likelihood of engine damage along with oil pressure and compression checks.
Any other suggestions or opinions would be welcome. The engine sounds good, seems to run just as well, but if the turbo got damaged (it's getting replaced at this stage) there's no doubt that oil starvation was an issue.
