DPF Stats 0 - 160,000Kms
  • DPF Stats 0 - 160,000Kms
    2018 GXL Prado:
    ECU firmware updated early 2019. Both Custom Modes enabled. New DPF installed at 80,000 service (didn't need it, but got it anyway plus 10 year unconditional warranty). Kerb Mass = 2,740Kg+, GVM Upgrade 3,500Kg.
    Click image for larger version  Name:	image_27384.jpg Views:	6 Size:	49.6 KB ID:	769212
    Click image for larger version  Name:	image_27385.jpg Views:	6 Size:	47.7 KB ID:	769213
    Click image for larger version  Name:	Economy 02.jpg Views:	0 Size:	69.7 KB ID:	769217
    Notes:
    a. trips < 5-8Km won't produce the conditions for DPF to start a burn in winter. This is how long it takes to warm the engine to start/resume a regen.
    b. 2019 ECU update significantly reduced the Kms between regens at highway speeds, and significantly reduced the time to complete a regen.
    c. DPF burn quits at 8%, the residual energy carries the burn to 6%, and at times 4%, 2% or 0%.
    DPF Manual button has Custom Mode enabled, used 9 times so far.
    RPP
    Similar to mine except custom mode 2 (the switch) has never been operational despite the dealer having 3 or 4 cracks at it. Custom mode 1 (the flashing light) works fine. My scan gauge gives the same readings as yours.
      Had the same problem. Rang around a few other Dealers until I found one that had successfully enabled Custom Mode 2. They got my business now.
        In Sydney by any chance?
          Adelaide.
            Bugger!
