2012 Prado 150 series Central Diff Lock light flashing
    Probable actuator fault. Needs Techstream connected to 4wd ecu to properly diagnose or remove the actuator to check for water ingress etc. (As Piggy stated above)
      The mechanic I took it to the second time around swapped the actuator with one that works perfectly fine, and yet the flashing light continued apparently. He was kind enough not to charge me for his time as he wasn't able to solve the problem.
        Has anyone put techstream on it yet? If not, I'd suggest taking to Toyota or someone with Techstream, and knows how to use it. and having the items checked thru that.
          I've booked the car in at another Toyota dealership for August 10. I'll mention Techstream.
            Reckon a Scangauge 2 would help?
              Techstream is made for these cars, scangauge etc will not show what Techstream will.
                Took the car to Toyota dealership again and they've come up with close to $4000 worth of repairs. I wonder why they didn't pick up on any codes or faults the first time I took the car over.
Name:	Screenshot 2021-08-11 073826.png
                  [QUOTE=WHOAMI;n759337]Took the car to Toyota dealership again and they've come up with close to $4000 worth of repairs. I wonder why they didn't pick up on any codes or faults the first time I took the car over.
                  Did you ask them to, (did they) Plug it into techstream? Theres some info around online about people pulling the actuator apart and cleaning/ greasing it and its fine afterwards. Common issue if they arent used every few months.
                    [QUOTE=Piggy;n759339]
                    The problem at the service centre is that I don't get to speak to the mechanic who worked on the car. Instead, the lady at the front desk is the one who deals with all the questions and often doesn't give the full/appropriate info. Also note that I am in Port Hedland, WA, not really spoilt for options. Got to wait close to a month to get a booking.
                    Also, when I took the car to another mechanic(not Toyota), he actually swapped the Actuator with another one from a perfectly functioning car, and the light kept flashing apparently.
                      Another thing I noticed was that, when the CDL switch actually works, I can hear a clicking noise when I push the switch to activate and deactivate CDL. However, when the CDL light starts flashing, and I try pushing the switch, there's no such noise. I'm thinking, maybe its the switch that's playing up. Any idea on how to remove it and clean it, or replace it with a new one?
                        Hi there! Any resulting to this? I am experiencing very similar in a 2015 Prado GXL
                          Hey all, I have the exact same issue with my 2010 150 GX. At first the CDL light was flashing and 4L wasn't working. I did the following things:
                          1: I pulled the transfer case actuator apart and did a clean and put it together to find that the cruise control now was no longer working. Did some reading and found that was beacuse I didn't time the gears right.
                          2: I pulled the actuator out again and did some reading on how to retime them and my cruise control and 4L worked again (phew) but my CDL was still on....
                          3: Took it to Toyota to run their scan tool and take a look and they said I need a brand new transfer case actuator and quoted ~$5k.
                          4: I found that Toyota also untimed the gears so my cruise control didn't work so I had to redo that myself afterwards the bastards. Decided I'm staying AWAY from the "stealerships" for as long as I can. After moving around with the actuator zig zagging at different speeds and putting back together I found that the CDL light was now NOT flashing BUT was still on and the button didn't change anything..
                          I'd put photos in but it's not letting me upload them or do links??
                          • #28
                            Sorry for the late reply. Been a bit busy with moving and other stuff. The actuator on my prado was faulty and had to be replaced. I was quoted around the $4k+ mark. luckily when I purchased teh car, I also got myself the warranty that they were offering. The whole cost of repair was covered. I have sold that car and bought myself a 2022 Prado now.
