Hello,
I have an early model Dual Kings air compressor that I'd like to hardwire into my vehicle, and I'm looking for some advice on the best mounting options. It's quite a large unit, and I've managed to fit it into the second battery slot, but it comes into contact with some rubber pipes, and I'm not sure if that's ideal (pictures showing this at end of post).
Has anyone found a better spot to mount it, maybe behind the side boot panels under the cup holders? I know people have done this with smaller units, but im wondering if anyone has managed with a larger unit.
Since I'm a beginner when it comes to auto electrics, I'd like to quickly outline my plan for this installation. I intend to run a positive and negative wire (could someone recommend the appropriate gauge?) from the cranking battery to the air compressor and connect it via an Anderson plug. Is this all I need to do, or should I include a fuse or circuit breaker between the battery and the air compressor? I've seen some YouTubers mention this step, but I'm not sure if it's necessary as I would normally just connect it with the clamps direct to the battery?
Any guidance or suggestions would be greatly appreciated!
Vehicle:
2010 Prado GX - 7 seater
Air compressor details:
Thumper max dual air compressor
Model:: WM102-15C
Voltage: DC12-13.5V
Max. Pressure: 125 PSI
Amperage: 90A
Air Flow: 300L/min
Under bonnet mounting option:
https://prnt.sc/0sTUTfWHkc7z
This is the unit itself:
https://prnt.sc/Y7v51VuneM0B
Vehicle:
Model:: WM102-15C
Voltage: DC12-13.5V
Amperage: 90A
Air Flow: 300L/min
