1KZ multi infomation display
  • 1KZ multi infomation display
    Does anyone out there have a 1KZ powered car that has the multi info display??? The display that shows temp/ fuel usage / Distance to empty....
    http://www.pradopoint.com/showthread...nction-Display
    Hope that helps
      Na wasnt any help but thanks anyway!
        Grandes have them as standard. At least mine does.
        2003 Prado Grande TD Auto Pearl White
          I've got a 2005 gxl to which I fitted a m f d I got from a wreckers that was out of a Grande
            Same as pepdebollox, I got one from a 2003 or 2004 petrol grande from wreckers in my 2009 1kd GXL prado.
            Just hunt around at wreckers for it and fit it in. plug and play which was discussed in another thread.
              as stated in the title i want to know if anyone has a 1KZ car with it in
              i know 1kds work and the V6 as they have the data stream 1KZ ECUs do not have a data stream
              its never going to be "plug and play" in my car its a 90s with 120s Engine box and ECU
                MickL put one in his 05 1Kz plug and play I believe.
                  Thread has been moved to the 90 series section to avoid confusion.
                    well its been moved to the wrong section then , no 90 ever come out with it , my 90 runs a 120 ecu so hence the 120 section
                    Thats what i want to hear someone thats put one in a 120!
                      Plenty of people have put them in a 120.
                      Blake
                        I don't mate but retrofits are a thing I know about!
                        Can I be of any assistance?
                          Quite possibly. .. wiring it in is no problem at all thats my forte
                          Its weather its actually going to work with a 1KZ but if ppl are saying they have a 1kz WITH the MFD then ill look for one
