Radio audio distortion
  • Radio audio distortion
    hi guys,
    when i turn on my radio a get something sounding like a distortion and when i push the gas it gets more loud. i have a top of the range pioneer head unit and a rockford amp. anyone suggest what might be the problem?
    Re: weird noice
    Sounds like alternator whine. Was the headunit recently installed? It could be due to an earthing problem from the installation.
      Re: Radio audio distortion
      If the power cables and the RCA leads for amp are run close to each other this can cause a problem similar to what you have, it often makes it sound like you have a supercharger whine.
      '98 Grande V6 - ARB Sahara bar, IPF HID spotties, ARB compressor, GME UHF, OME Sport suspension, 265/75 MT ATZ 4 Ribs, steel rock sliders, Safari snorkel, Tigerz11 winch, rear ARB locker, Rhino platform rack.
        Hi there,
        this could be an earthing issue, I never use the stock earth on head units. They often induse noise, and they are usually thin and long. Also if your head unit uses more power than the stock unit the earth should be bypassed, for something thicker and solidly earthed.
        Kind regards
        Rich
        Goldmember, a Prado Grande 2000 model, because people out there have been turning music into gold. A mobile soundstage currently under construction utilizing old school multi-channel active system design. All to have an Amsterdam good time.
        Alpine CDA-7949e, Alpine ERA-G320, Alpine CHA-S614, Alpine DRE-A500, Alpine DRE-A200(x3), Alpine MRV-F407(x3), Alpine 3555, Alpine 3553, Soundstream Reference 500s, Soundstream SPL15(x2). Dunno about front/rear stage yet, might not need all the crossovers...
          Firstly narrow it down a bit, is the noise there when the engine and all accessories ie
          inverter, fridge etc are unplugged?
          What does the distortion sound like, is it static ie a tick tick sound, a whine or distorted sound?
          When you say it gets worse with throttle do you mean it speeds up or just gets louder?
          If it has a cd does it do it with a cd playing?
          Has it always been there or just started?
          LeighW
