1KZT-E Timing Belt Change Walkthrough
  • 1KZT-E Timing Belt Change Walkthrough
    Found a great walkthrough on changing the timing belt in a 1KZT-E
    http://www.dieseltoys.com/timing_belt.pdf
    amts
    Ninja Poster.
    Last edited by amts; 04-05-2012, 02:08 PM. Reason: Changed link from code to clickable link
    Malcom
    Prado 95 TX turbo diesel
    LC100 GXL turbo diesel
    thanks, 150k coming up soon for mine
      Perfect. I'm doing mine tomorrow.
      95 3.0 Camp Car, 150 V6 Daily Driver[SIZE=4]
      [/SIZE]
        Very nice.
        [B]KZN185 SSR-X 1KZ-TE[/B]
        | LSD | OME 2" Lift | Cooling Mods | DP-CHIP | 3" Zaust | Alpine Sound | Tint | T-Bar | Boost Controller | EGT Guage | Auto | Dual Batteries | Dicki Seat | OEM Intercooler | CB-Radio | Cruise Control | Whispbar HD Roof Racks | Prado TJM Bullbar | Great Whites LED |
          Excellent, I did mine the other day as well as cleaning the intake.
          Now does anyone know how to reset the timing belt light on the dash?
            Good tutorial, only things I would add is a wipe of grease between the lips of the camshaft seal, and I personally replace the tensioner and idler. It's just cheap insurance, if either let go and the belt jumps a tooth or two it may well cost you an engine. Also check whether the seal has cut a groove in the camshaft as the OE seals are Viton (I think, by the colour) and can cut a mean groove in the shaft. I may well use a nitrile seal next time (not as savage as viton, will wear a little more before the shaft does) and may have to space it out a bit in the cover.
            cheers
            Steve
            t303
              http://www.pradopoint.com/showthread...-warning-light
              should do it ;-)
                2004 Silver GX 4spd auto 3.0 T/D, Safari snorkel, dual batteries (Piranha), Bilstein suspension upgrade & lift, ARB winch-bar, diff breathers, GXL steel wheels and 245X17 Cooper AT3s, Autosafe cargo barrier, Kulkyne side awning & Oztent, Toyota 3 bar rack, Maxtrax, other ARB & TJM recovery gear, Engel and Waeco fridges, Towpro, GME uhf, AMTS recovery points, Tvan
                  You guys living in Aus. must have electronic dashes? mine is not so the walkthrough on the 120 series thread will not work on my prado! any other advice? I have pulled the dash off.
                    Ah, sorry, but you haven't got either your location nor vehicle type on your profile, and my crystal ball is at the jewellers getting cleaned :-)
                    So... what is the actual model designation eg KZJ95, KDJ120 etc?
                    IIRC if you have a mechanical odometer there is a screw in the back of the instrument panel that has to be moved from one hole to another to extinguish the light.
