**Update 17th August 2020**
2000 GLX Prado 3.0L Turbo Diesel (1KZ-TE motor) (330000km) 4 speed auto
Hey all, I have just bought my first Prado and am trying to work out a couple of minor problems. I've done extensive reading throughout this site on the subject and have learned heaps of great knowledge! So thank you all! Though I have made some improvements, I still have not completely resolved my issue(s).
Overview: Hard to start on cold mornings but runs beautifully throughout the day. It runs very well on flat road however it loses its power up longer inclines.
Cold starts: Have been an absolute drama. The colder the morning, the harder it is to start. Had a couple of much warmer mornings recently and the engine started much quicker but still unacceptable. I have to keep cranking the engine for about 10 seconds while it slowly starts igniting. Once it gets going, starting is pretty much instantly any other time throughout the day. I did have an issue where the primer pump wasn't holding prime. Have replaced that and it now holds prime however still having start issues.
Update: solution found! Spill Control Valve was causing issues. No need to replace. See final post for fix.
Sluggish up hills: Driving with just myself in the car, no load, 120 km/h on the freeway (110km/h speed zone) no problems and some headroom to go faster. Suddenly get to a long gentle incline and the car slows right back to 100 km/h with foot down and no more acceleration. I am learning this is a common issue with this motor due to timing and fuel delivery and am in the process of exploring options to adjust these.
Things I have tried:
Cheers in advance!
- New air filter and fuel filter
- Cleaned MAF and MAP sensors/filters
- Replaced MAP sensor filter (oil separator)
- New higher rated crank Battery's - slight improvement in starting)
- Replaced Glow Plugs (No difference)
- Used an Injector cleaner
- Checked the ECU mainboard - it is in excellent condition. No swollen components or leakage.
- Replaced fuel hoses either side of fuel primer pump.
- Replaced fuel primer pump (now holds prime - still slow to start)
- Timing belt within its service date
- Tipping a cup of warm water onto the Spill Valve body (Didn't help)
Cheers in advance!
