What did you do to your 90 today?
  • It was that big step just over half way on the first climb that done the damage, normaly I would have took the easy root, but because the Patrol could not make it I had to give it my best shot. the winch did come out but I made it up!
    No short term damage, but the trailing arm was defiantly bent, they both will be replaced/strengthened. sub tank had no leaks, but fuel gage stopped working.
    I know its a lot of work to happen at once, but I does make sense to do it all at once. $$$$$$$$$$$
    I do have a rear bush kit and swaybar drop kit to go in aswell. should make it even nicer to drive on road.!
    Hilux for work, Prado for play.
    locked and loaded!
    • Old girl back from mechanic. New rear seal. Nice not to have the smell of oil burning after it drips onto the exhaust.
      • Over due wash and wax. (stubborn bird sh#t everywhere... ). It was a big job ok :P
        Thinking of roof racks and roof box soon.
        • OBD1 data logger and real time sensor readout wired in.
          • Originally posted by RanJ View Post
            What is that? Is that like a scan gauge for us with older cars?
            Blake
            • Yep... Still working on it. But details will come.
              Trying eliminate noise in the signal at the moment.
              • I sold it
                So now i've got 5 weeks of researching before i need to buy.
                Not an easy task from up here
                John
                • Originally posted by letsgoplaces View Post
                  I sold it
                  John
                  Oh no! What ideas do you have for it's replacement?
                  • Made a water injection kit for her. Promising results.
                      Ooh do tell the results. I wouldn't even know what to look for, for the results...
                      • Tested the rear suspension today (5x adjustable rear links with altered geometry) and found some rear tyre rubbing on compression, prop shaft vs aux tank grinding, and quite a bit of rear steer... so I have some fine tuning to do...
                        • Amazing Glen. No doubt you will sort it quickly.
                          • That's pretty nuts isn't it. Nice one 👍 certainly looks different to my brothers 90
                            Blake
                            • Glen... I just showed a picture of your 90 to my 90... I think it just blew another strut!
                              OK, water injection... So far the results have been a substantial increase in economy. I have no numbers yet but my 90 used to deliver around 20l/100km around town. The same drive home yesterday (70km) the needle barely moved where as it usually drops a minimum of two needle widths.
                              Slight increase in low down torque
                              Under hood temp "feels" much lower. Keep in mind the only thermometer used is the skin on my face as I lift the hood.
                              Detonation... Gone.
                              • Yeah it's drooping a little more than before even with the sway bar in place. It'll go much further without the sway bar, but then the coils fall out, lol.
                                RanJ that's some very impressive results, especially regarding temps and detonation. When I get back to the engine mods in future I'll definitely appreciate some tips from you
