What did you do to your 90 today?
  • Originally posted by glen_ep View Post
    Looking good, and welcome to the forum.
    thank you
    [URL="http://www.pradopoint.com/showthread.php?35754-1997-PRADO-GXL-(lap004)"][SIZE=5][FONT=Book Antiqua][CENTER][B][FONT=Century Gothic]MY 95 SERIES PRADO GXL.[/FONT][/B][/CENTER][/FONT][/SIZE][/URL]
    • Finalised my dual battery setup over the weekend, has taken 2 months on random weekends doing little bits at a time, then finally hunting for the battery I wanted for the best price, but I got there in the end!
      TJM monitoring and linking system with all wiring - $150 new old stock
      Hoses to move charcoal canister - $10
      Tray, leftover scrap from home - $0
      Teflon supports and bolts - $25
      Teflon breadboard to hide bolts - $0
      Battery harness/holder and terminal covers - $25
      D34 Optima battery - $259
      Dual battery all installed $469
Name:	teflon supports for tray.jpg
Name:	teflon to conceal bolts.jpg
Name:	optima d34 installed.jpg
Name:	tjm battery monitor installed.jpg
      SAMUEL
      • nice Samuel , any photos of the relocated charcoal canister ?
        2018 GXL 2.8 1GD,
        • Yeah, relocated to next to main battery and fan shroud.
          Made an ally bracket that extends from underneath the main battery to hold it in place, extended hoses and power to it.
          SAM
          • Nice work Sam, looks like you've been busy. Hopefully the extra weight of the new battery will hold the nose down next time you launch it skyward. 😃
            Rig build here
            • hello all
              got 475000 kms on my rv6 all original and motor suddenly started vibrating when I took off from traffic lights and was shuddering under load.Had horrible thoughts of head gasket but turned out to be lead was cooked so new leads,new spark plugs $200 all up and happy with my car again.
              cheers mark
              • Thanks for the photos Sam I will be looking to do that shortly, have have the isolator for some time now!
                2018 GXL 2.8 1GD,
                • Originally posted by Mattfunk 120 View Post
                  Nice work Sam, looks like you've been busy. Hopefully the extra weight of the new battery will hold the nose down next time you launch it skyward. ��
                  i doubt it, just gotta hit it harder
                  SAM
                  • Finally got the time to have the suspension changed, dobinsons all round. Thanks to #############, job well , done. The rears arnt that hard to get to, just need to fit the pacemakers
ID:	652006Click image for larger version
ID:	652007Click image for larger version
ID:	652008Click image for larger version
                    oceanracer
                    Moderated member
                    • Originally posted by oceanracer View Post
                      Finally got the time to have the suspension changed, dobinsons all round. Thanks to #############, job well done.
                      Give us a look
                      Please!
                      Rig build here
                        [ATTACH=CONFIG]20453[/ATTACH][ATTACH=CONFIG]20454[/ATTACH][ATTACH=CONFIG]20455[/ATTACH][ATTACH=CONFIG]20456[/ATTACH]
                        I remember when mine were that yellow
                        SAMUEL
                        • Originally posted by juc33_prado View Post
                          [ATTACH=CONFIG]20427[/ATTACH]
                          [ATTACH=CONFIG]20428[/ATTACH]
                          [ATTACH=CONFIG]20429[/ATTACH]
                          SAM
                          Is there a reason you put a yellow top in the engine bay? My experience has taught me that the yellow top isn't a fan of the heat ir vibrations.
                          • Originally posted by RanJ View Post
                            Was recommended from a few as the best option for my purposes, also quite small size for power/ah etc, which I don't have a lot of room due to the nature of the install.
                            I still intend to cover it with a heat shroud, just gotta find the correct material.
                            If it fails, Optima will cover it, they say nothing about heat damage being an issue for warranty.
                            And vibration would be the same if it was an internal install above the rear wheels I assume?
                            SAM
                            • Done a handful of things over the past few days...
                              Repaired the rear Ac controls as the screws had vibrated loose and the controls no longer slid.
                              Replaced the battery terminals with a unit from Projecta that is perfect for dual battery setup... I'll post pictures shortly.
                              Removed passenger seat to repair sub amp... now have bass again but in putting the seat back in again the front left retaining nut broke it's weld and I'm not sure how I'm going to secure that bolt properly mow as the nut isn't under the car... its inside a body support rail. The bolt is in the nut reasonably tight but it is loose and does allow for some seat movement. Have a long haul coming up with my wife soon so I'll definetly need to fix the new ejector seat beforehand haha. Although she says I've been pissing her off lately so maybe this is my chance haha.
                              Attacked the overhead console a little more. Looking at fibreglassing the new one but not only holding a radio but also some of my gauges to get them off the A pillar. Will shaping. With foam soon and show the results.
                              Considering pulling the carpet and roof lining to recover them and add some sound deadening while I'm there.
                                Something like this to replace it with?
