hi folks,
i am driving 2002 prado diesel with 135000 km (only), i am having a problem with the engine temperature.
the needle shows almost minimum most of the time, and after a tough uphill climb it can reach the normal heat point but only for a short time.
in addition, the heater in the car is barely working, and starting to push lukewarm air only after 20 min drive, i also mentioned that the fuel consumption is bad, somewhere around 1:7 (liter:km).
after consulting with some folks all said i need to replace my thermostat...
i am wondering if somebody here have a tutorial or any other helpful knowledge of how to do it.
i assume it should be on the bottom big house, but, before going ahead i would like to know how complicated is it and how many additional parts should be removed before getting to the thermostat.
thanks in advance.
cheers.
thanks in advance.
cheers.
