Flex your muscles...
Originally posted by glen_ep View PostI once tried disconnecting the front sway bar.. quite scary how much it rolls on road!!1997 3.4 V6 Rv. mods; 1 1/2 inch bodylift, 285/75/R16 cooper STTs, 16x8 sunraysia style black steel rims '0' offset, 2 inch heavy duty springs, bilstein shocks (80 series rear), GME remote mounted UHF.
Originally posted by draycon View Postyeah, is a bit haha, but i find it stays a bit leveler when flexing though rough sections since the front moves so much easier,glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
i dont find much terrain scary, probly something to do with the young brain. i guess ya get used to it and ya have to know the vehicle and its limits and respect those limits1997 3.4 V6 Rv. mods; 1 1/2 inch bodylift, 285/75/R16 cooper STTs, 16x8 sunraysia style black steel rims '0' offset, 2 inch heavy duty springs, bilstein shocks (80 series rear), GME remote mounted UHF.
Hi Draycon
What type off springs are you running?
Cheers DesLast edited by DJD 95 TDI; 04-01-2012, 06:08 PM.2000 95 Rv TJM Bull Bar,TJM Snorkel,TJM 2'' lift,TJM Prolocker,Dual Battery,Icom UHF,TJM Awining,16x7 Black rims,Power Shower Unit,
XRAY VISON 90W HID Spot Lights,Rhino Roof bars and more.
Originally posted by draycon View Posti dont find much terrain scary, probly something to do with the young brain. i guess ya get used to it and ya have to know the vehicle and its limits and respect those limitsglen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
hey Des,
they are a heavy duty ( +150kg i think) old man emu spring, but it is definetly more than 2 inchs high than it was...but it was probly sagging out a bit...300,000 kms on the factory stuff, only just managed to replace it haha.
and glen.... we have our moments :P there are plenty of hills around perth, just have to find the good ones1997 3.4 V6 Rv. mods; 1 1/2 inch bodylift, 285/75/R16 cooper STTs, 16x8 sunraysia style black steel rims '0' offset, 2 inch heavy duty springs, bilstein shocks (80 series rear), GME remote mounted UHF.
Here's one from the other day. Its nothing special compared to some of the custom suspension setups here (Draycon), but it's still better than the cruddy flex of the 120 series.
Things will be different when I build my 80 series tonka truck.[B]Declan[/B]: [SIZE=1]1997 GXL 4.5 Auto 80 series on [B][COLOR="#FF0000"]LPG[/COLOR][/B], ARB bullbar, 2" OME lift, 32" MTZ, GME UHF, rear ARB locker, Kaymar spare wheel carrier[/SIZE]
just decided im going to extend my rear sway bar in the next few weeks, but turn them into a quick disconnect setup, and swap over to a shaft mounted bumpstop, to get the absolute max travels from the longer rear shocks. then ill get some more shots for everyone.1997 3.4 V6 Rv. mods; 1 1/2 inch bodylift, 285/75/R16 cooper STTs, 16x8 sunraysia style black steel rims '0' offset, 2 inch heavy duty springs, bilstein shocks (80 series rear), GME remote mounted UHF.
Recent flex shots:
Last edited by glen_ep; 01-05-2017, 09:05 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
The only real issue is tyre scrub on the inside of the wheel arch, but not bad. Everthing else looks ok for now.
did you ever have issues with your front driveshafts spiting out grease? As soon as i lifted it they spat grease everywhere, but boots not split, then I dropped the diff which was better but then the boots split cause they were hard. I ve had all boots replaced and cv's rebuilt but over the weekend I went for a run to Ingleburn and back down the M7 and they have leaked a little, the mechanic checked them today and said it was ok, not much grease came out though90Series GXL 3.4L V6 - Snorkel, sports muffler, 3" suspension lift, 285's, 30mm diff drop, Brown Davis bash plate. Coming soon: 2" Body Lift, custom comp style bar & sliders just for starters
