What’s the largest size tyre for a 90 series
  • What’s the largest size tyre for a 90 series
    I’ve got a 95 series that doesn’t have a lift, and is currently running 225/75/r16s
    whats the max size tyre I can run without installing a lift kit?
    the tyre shop has said 245/75/r16’s will fit, but 265s are a bit of a stretch.
    Thoughts?
    55/80r63
      I have Yokohama Geolandar A/T G015 265/70 R16 on my 2002 vx Click image for larger version
        So - without flairs the max size that'll fit and not stick out is 245/75/r16.
          I have 265/75/R16s on 100 series Landcruiser 16x9 rims which I *think* have an ET15 (+15mm) offset. With flares, my tyres are only just legal I reckon!
            I have 265/75/16s on VX alloys and they don't touch anything.
              It really depends on your specific vehicle and setup. If you are looking to fit larger tires without a lift kit, 245/75/R16 would be the maximum recommended size. However, it is always best to consult a professional to make sure your vehicle is capable of handling the larger tires.
