BUG reports....
  • #91
    Actually you posted:
    I've also noticed a user name that is like "Ian & JaneG" but displays as "Ian&JaneG" in the author section for each post.
    As I said to search out every &Amp is too much to bother with currently, much more on my plate. As they show they will get done.
    • #92
      Ok so you are unable to update all in one hit. Fair enough.
      Not sure if this is a bug but if I access Forum -> Community -> Albums I'm only seeing a single album where as last week there was a dozen odd albums I think. Does the album area only show albumns that have had recent activity? I know that MidLife Crisis has an album and if I go to his user then i can access his Album but I can not see it in the general Album list (as it only shows me my own Album).
      [COLOR=#000080]Nick[/COLOR]
      • #93
        Try:
        Settings > General Settings (bottom left) > Thread Display Options > Default Thread Age Cut Off: Show All Threads
        • #94
          Nah that's not it XLR8 as I had changed that setting right at the start of this forum. Have you had a look at the Album list?
          • #95
            Nah I haven't, where do I find them?
            • #96
              Not sure if this is a bug but I can't locate replies to PMs in the Sent folder today. I can see older replies, just not ones I have made today.
              • #97
                Exactly where I pointed to them in my post above
                • #98
                  I solved my own problem, PP doesn't keep copies of Sent PMs by default anymore. There is an option under Settings > General Settings > Private Messaging to keep Sent Items, you just need to select it again.
                  • #99
                    When I visit Whats New?/New Posts link and there is say 15 or 20 threads that are showing new posts, after reading a couple I will return back to the New Posts page & a large percentage of the threads disappear (magically become "read" posts without me viewing them) I have checked that I have Default Thread Age cutoff set to "Show all Threads" in my Gen settings. this is annoying as it makes it very hard to keep up to date with all posts as they are being displayed as "no unread posts"...
Name:	Post status.JPG
                    • Back again
                      Back again, the swap took away my ability to answer or post any threads.
                      Had a password problem weather changing my Email address was the reason who knows.
                      Makes me wonder how many others may be in the same situation??
                      All is good now thanks to Piggy
                      Fazza
                      It appears I have lost my avatar like many others, no big deal!
                      Admin: Bingo.... Had a password problem weather changing my Email address was the reason who knows.
                      Piggy
                      Water pistol pilot.
                      07 Silver Ash, GXL, D4D, Auto. Lifestyle rear cargo rack. 2500 kg Tow bar with Tekonsha elec brake controller, Rear dust deflector, Mio Sat nav, (Still trying to fault the Dunlop AT20's)
                        [ATTACH=CONFIG]1459[/ATTACH]
                        Im still getting this too. I posted a query on page 1 that was explained to me but I didnt really understand the solution offered.
                        CraigM has explained problem a bit better than me, so hopefully can be explained or resolved if there is a fix
                        Daz
                        2004 TD GXL Auto Prado
                          If you use this link, it will at least list all the posts in the last 24 hours.
                          www.pradopoint.com/search.php?do=getdaily
                          • Time stamp for post seems to be wrong
                              Thanks Andrew. Is anyone else experiencing same issue (losing unread posts) or is it just Daz & I?
                              • You are not loosing the posts. The "New Posts" link shows a listing of posts that have had activity against them since your last visit to the site. Each visit to the site is determined by time so if you access now then you might have a five minute or ten minute time before you are recognised as another visit. You may be accessing the site the whole time reading the various posts in the new posts area. When you refresh the "New Posts" and you have only read some of them then you are giving the list of posts that have changed since your last new visit commenced. This is working as a standard session that all user based websites utilise. The previkous forum just took a different approach to how the links where pulled back.
                                If you don't want to "loose" the list then read them all before you refresh.
                                Schaffer
                                Addicted PP Member
