Welding could damage computer?
  • Welding could damage computer?
    I'm hoping to get another tab welded onto my bullbar (for flag) but I've been warned if not done correctly it could lead to damage of the computer. Anyone know how this works and what would be the correct procedure?
    If you disconnect your earth and positive leads then it shouldn't get any current to anything electronic. That's what i'd do at home if i was welding something on the car just to be safe.
      What he siad.
        I think you will find its a bit of an old husbands tale, so long as the wedding earth is well secured its a million to one shot to cause an issue.
        There are literally tens of thousands of guys around the world running mobile welding setups and welding all the time on the back of their trucks without disconnecting any battery leads, it's a non issue for all these guys.
        I've welded on my Prado quite a few times without disconnecting anything and not had an issue.
        But hey, disconnect the earth lead if it makes you feel better.
          I've actually destroyed an ECU while welding mig welding on a vehicle, but it was a Nissan Pulsar so not sure if that counts:lol: (mind you we're making and assumption as the vehicle wouldn't start after some rear end body repairs.... could have been a random!)
          Make sure the earth is good (clean) and close to the weld as practical.
          Mick
            It's not just the ECU, a poorly connected or placed welding earth can cause problems with mechanical components as the current finds its way to earth.
            [B]Steve[/B]
              Hello Rainman,
              This has been an issue ever since alternators ( with electronic diodes ) were fitted to vehicles, most welding tradesmen ( persons? ) have suitable surge suppression equipment to connect across the battery to protect all electronic components from random current surges. even connecting surge protected jumper leads to the battery will protect the ECU. Standard disclaimers apply. Dont blame me, I did not do it etc.
              regards
              Ross
                As AJ said , it is an old husbands tale , i owned an exhaust shop for 16 years and Never disconnected a battery to weld , i used an antizap device across the battery when i did anyway, and also disconnecting a battery in modern cars can cause more issues for you now if the modules in the car are not depowered correctly
                i.e a VF Commodore , if its not done right you can wipe the memory from the bcm etc , any only a dealer can re write it
                  And there's nothing like an electrical question to bring out a range of different opinions. :lol:
                  Welder does oil rig and deep sea work, so not sure he'll be set up for protecting the electrics of my high tech 95 series but it seems like disconnecting the batteries might be the least that should be done to cover all possible eventualities. Cheers
                    Your 95 is completely safe. Don't stress it.
                      I've had some brackets welded to my aluminum bullbar recently with no issues. As mentioned by others, disconnected the batteries and the guy doing the welding made sure the earth clamp was close to the weld and secure.
                        When I welded my rear bar tabs on I took the precaution of disconnecting the pos and neg earth from the battery, may Or May not matter, but they even do it for our heavy mining equipment, really it's quick to do just a pain going through and resetting the power windows etc. but why take the risk
                          they all say it doesn't have any effect on what your welding ( pretty much every exhaust shop will weld straight on the car without disconnecting anything)
                          i have just replaced the power steering ram and a brand new race car that leaked on start up
                          i called the company and he said they must have welded on the car and it has arked through the bronze bushings to the shafts
                          when i pulled it apart that is exactly what i found $600 later & 2 weeks for the parts and it was fixed
                          now the bypass shocker shafts have the same issue about $240 to fix each shock ( the shocks were $2000 ea !!)
                          dont put the earth on the rear of the car if your welding the front, put it on the item your welding it to and start the arc on the part that has the earth !!!
                          i will tell you this
                          if you take the time to properly fit the earth point as close as practical to where your welding it SHOULD be fine
                          but hindsight is a wonderful thing
                          that is my opinion !!
                          in a past life i used to weld up submarines, but they all sink ! so now i build race cars that run down the Finke !!
