Optima Battery Terminal failure
    Ive had 2 over the years that stopped holding charge. Id never buy one again. Seeing this is just adding to me not liking the brand
      Originally posted by Rainman View Post
      The cause looks pretty obvious to me. ;-)
      What are you saying Donald?
      Micheal.
        Look for the red circle in the photo
        Greg - 08 D4D Prado,
          I am referring to that - and a Donald that doesn't like Mexicans...
          Micheal.
            i can assure you guys the terminal was not over tightened it did however come off when removing lead although the wing nuts weren't that tight. Only bought it because it was the only agm that would fit in the space need more ah this time.
              Why has it got such a deep terminal mark in it?
              Mine are bloody tight, but no marks at all.
              Weird stuff.
                Lead is a soft metal, in fact you are hot working most lead alloys at normal room temperature. Thus the terminal post will deform either side of the clamp but there would be no impact below the plastic case. Possibly it has been wrenches back and forth which has caused a fracture to appear but it looks to me like a manufacturing defect. Incorrect alloy or a casting flaw. Obviously that is based on the couple of pictures and not a proper inspection so could be wrong.
                  I'm 42 years old i've had a number of vehicles in my life. none have had the terminals fail.
                    So were about the same, I have been working on motor vehicles for 25 years & I have never seen anything like that.
                    I have been a century & optima dealer for over 10 years.
                    I don't see crush marks in the lead terminals like that. I'm not saying its caused it, but looks sus. Too tight!
                    If I was optima, I'd sort it!
                    Thanks for sharing.
                      Oh build a wall Micheal, or was it a bridge????
                        Worth sounding it out with Optima, but ultimately your contract (incl your warranty) is with the company who sold it/installed it for you, and that isn't Optima.
                          Guys just letting you all know the upshot of my attempted warranty claim in case you are interested. Neither Optima or the installer will cover the battery, each blaming one another. Going to give Optima a wide berth for my next vehicle. If a battery is only going to last 3 years i'll stick with a standard lead acid deep cycle.
                          • #28
                            ive heard that a fair bit from unhappy optima customers
                            • #29
                              Heard too many bad reports about Optima's, that's why I went with SSB AGM battery
                              • #30
                                If you have the time take them to the small claims tribunal. Not lasting the warranty period is ridiculous. Failing that tell everybody about the failure. Use your facebook page even comment on their page. Rise the little people..........JMHO
                                Cheers Brian. 2006 Grande D4D
