1Coolbanana's Grande Build Up
  • #46
    Im using a Uniden AT870 ground independent with two whips, a short 150mm 3db and a 630mm 6.5db.
    Is this a decent antenna?? I have no idea (as usual)
    The 6.5db long whip was going ballistic and drove me nuts in the first 7 k's! Took it off.
    The short 3db whip is ok.
    Still not that impressed but I dont think there are many options???
    Anybody got any good ideas, would love to hear them.
    Alternative antenna types maybe???
    • #47
      Originally posted by 1coolbanana View Post
      Damn you, damn pradopoint and damn ebay. you all keep costing me money just kidding
      i bought the stebels from same ebay seller (very quick delivery) and fitted them last night. they sound great and i am very happy with my horn, ahhh prado's horn....
      thanks for the link and advice too (will let you know how i go with the gps/reverse camera)
      [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
      ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
      • #48
        No worries mate, glad your happy with them.
        • #49
          OK, so the lift is done after much deliberation and got a chance to give it a hard time.
          Ive gone with the Tough Dog adjustables.
          I got the struts fitted mainly because I could be bothered and the price was very good.
          I know they arent popular and people have strong opinions about them but got these specifically for a number of reasons.
          1) The local service from "Mr Toughdog" himself is exceptional and only just down the road.
          2) The dimensions to suit the Prado (with OEM airbags) I had in mind were very specific and they were the only ones that fitted the bill exactly.
          3) Adjustable which is an absolute gem to be able to do.
          4) Suited the airbag perfectly with a total of about 10mm in extra extension, WITHOUT MODS.
          5) Importantly, EVERY person I spoke to who has the current gen of Tough Dog shock is wrapped in them without a single issue.
          So, I took it out yesterday and first thing I wanted to prove was I was going to loose an airbag.
          Rear with spacers for the sensors sit at 825mm with 65-70mm left.
          Spacers either side for the sensors
          Front using TDC974H springs sitting at 790mm with a massive 100mm of travel left which is significantly more than all the other brands.
          Rear wheel is off the ground
          1coolbanana
          • #50
            No sign of bags coming loose.
            Different angle on max extension
            I will be persuing the R clip sometime but there is no hurry I reckon with this combo.
            Im wrapped in the result actually and the adjustment works brilliantly.
            Perfect height combo for me,
            790 front with max extension at 890 (before was 735 and 845)
            825 rear with max extension at 900 (before was 790 and 890)
            Very happy and the ride is awesome.
            On a road trip and around town I had it set to 4 clicks, awesome handling but a bit hard especially with no load.
            Offroad, knocked it down to 2 clicks and it soaked everything up really well.
            Ive actually left it on two clicks, nice and plush similar to OEM but much better.
            1coolbanana
            • #51
              Couple more pics
              • #52
                Some detail shots.
                The TD front has so much more down travel that the upper control arm just kisses the springs.
                Front max droop
                Just touching and exactly the same both sides and CV angle.
                There seems to be no binding at this height.
                Ride height 790mm CV angle is only a few degrees
                1coolbanana
                • #53
                  Rear at full droop
                  Doesnt seem to have any dislodgement issues????
                  Hopefully wont need to retain but may still do the R clip mod Ive been thinking about.
                  • #54
                    Marc. Nice work and congrats on taking the plunge and going against the norm with the Tough Dog setup. Fantastic results with both lift and droop. Can you please confirm the height of the spacers used for the sensors?
                    • #55
                      Thanks mate, Im really happy with them, the ride is fantastic and the adjustment really works well.
                      Mine were not even to start with, the right side was originally 7-8mm lower so I ended having to compensate for this to get them level.
                      Left originally was 790, wanted 825 = 35mm @ 3:1 so I used 11mm spacer.
                      Right originally was 783, wanted 825 = 42mm @ 3:1 so I used 14mm spacer
                      You will have to work out what you want based on what youve got.
                      Hope that helps.
                      Marc
                      1coolbanana
                      • #56
                        Hi Marc, congrats on the lift. The rig is looking great.
                        Alan
                        [color=#0000BF](The MK II) 2012 GXL Auto Diesel, White, ARB Bull Bar, Warn 9500lb XDC Winch, ARB Alloy Roof Rack, Aussieoutdoordirect Awning, Toyota Tow Bar, Safari Snorkel, ORS Rear Drawers and Fridge Slide, ARB Battery System with REDARC isolator, ERPS 10 Pad electronic Rust Cont, 275/65/17 BFG AT's, Jumbuck Sheep Skin Seat Covers, REDARC EBRH Brake Controller, OME 2" lift kit, Air Bag Man high pressure air bags, ARB CKMA12 on board compressor.[/color]
                        • #57
                          Alan
                          Thanks Alan, I pretty happy the way its coming along and so far Im very impressed with the TD's
                          Marc
                          PS: Can you hear the crickets from the Cape? lol
                          1coolbanana
                          • #58
                            Hi Marc,
                            Nice rig, I just joined and I have only just bought my first fourby. Same as yours only white.Look forward to seeing more pics as your build progresses. Thanks for your comment about the ARB. I am getting one soon and it was between that one and TJM.Cheers
                            Shrek
                            • #59
                              you need some new upper control arms on the front.
                              good pics and write up too.
                              SIK-120
                              2008 Toyota Prado 120
                              • #60
                                Starting to tick the boxes now mate ..well done...
                                joey
                                -issue 52 Modified 4wds .
