Originally posted by 8608
View Post
Derek11's 2012 Blue Storm 150 GXL build up
Here is the wiring for the rear LED lights running from the roof rack to the roof gutter on the RH side.
running from the gutter to behind the rear door seal, the wiring is silastic in place
then runs into the rear door wiring loom
this is the switch on the back door to turn on the lights with the prado off, its also wired as reverse lights
hope this helps you SteveLast edited by derek11; 02-08-2013, 04:24 AM.Blue Storm 150 GXL 4D4 PRADO and 2014 Cub Brumby Camper
My rig build [url]http://www.pradopoint.com/showthread.php?25698-Derek11-s-2012-Blue-Storm-150-GXL-build-up[/url]
I like the roof rack wiring. I was thinking of doing that for the solar in feed when I fit the rack and solar panels. A permanent wire wont be in the way at all by the looks.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
I'm thinking about solar panels as well, as there are brackets that bolt on underneath the roof rack where the solar panel sides out, or get the stand alone solar because you always park the 4wd in the shade.Originally posted by mjrandom View PostI like the roof rack wiring. I was thinking of doing that for the solar in feed when I fit the rack and solar panels. A permanent wire wont be in the way at all by the looks.Blue Storm 150 GXL 4D4 PRADO and 2014 Cub Brumby Camper
Thanks heaps for that Derek. I'll hopefully get mine done very shortly.Originally posted by derek11 View PostHere is the wiring for the rear LED lights running from the roof rack to the roof gutter on the LH side.
Steve2013 [COLOR="#006699"][B][SIZE=2]Blue Storm[/SIZE][/B][/COLOR] D4D 150 GXL Auto, Opposite Lock Bullbar, Safari Snorkel, GME 3345 UHF + AE4018 Antenna, HR Tow Bar, TG150, HD Rhino Roof Racks, Foxwing, Dual Batteries, C-Tek DCDC Charger, ARB 47L Fridge, ScanGauge II, Internal Fishing Rod Storage, X-Ray Vision HIDs and LEDs, New PP Sticker.... [COLOR="#808080"][SIZE=1][/SIZE][/COLOR]
I will second that.. My awning is getting lighting very, very soon..Originally posted by stevep84 View PostThanks heaps for that Derek. I'll hopefully get mine done very shortly.
Steve[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]
My solar panel (s) are only used when we go campning. They sit on the roofrack which in turn sits on the factory NS rails. Looking at the install I reckon I will run a permanent cable the same way Derek has and fit an Anderson plug up on the NS rails. Then I only need a short patch cable to connect on the roof. Running down the driver's side works perfectly with the battery install. Saves working out how to protect the cable if I do a temporary run. Time to do some more mods.... And I have enough spare cable and plugs left over.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Fly home tonight, hopefully the dash cam will be at the post office and i can fit it in time for a trip up the Reynolds Track saturday. Then work out how to upload the footage.Blue Storm 150 GXL 4D4 PRADO and 2014 Cub Brumby Camper
the blackvue dash cam was at the post office, set up in the rig was easy, now just need to hard wire it to the 2nd battery. I'll get some photos up later.Blue Storm 150 GXL 4D4 PRADO and 2014 Cub Brumby Camper
Derek just looked at your pics for wiring running out above rear cargo door. Not sure going by picture but where the wiring loom runs down from roof to under rear door rubber did you silicone that up as well ?? Reason I ask is that is the same spot the water on the 120's is getting in (where the two panels are joined together) and then follows the rubber down to the bottom and sits there and starts rusting.. I can see the wire loom goes back in behind the drivers side through the grommet but if the water is coming in from the top I presume it would continue to follow rubber door seal to the bottom ... Cheers SteveFace lift 150 Prado V6 auto. No mods yet
