Originally posted by Dueler120
View Post
Brett's 120
BrettM , very nice project, feel free to have a look at my build up for the winch install.. which is currently in progress.. doing the same as you.. watching with interest,,, cheers butane[u][i][b][color=#0000FF] ..lets take her out for a spin... butane[/color][/b][/i][/u]
Hi butane, my winch bar project will be a bit later on down the track as I need to get a winch first so I can work out the measurements for the winch mounting plate and where to make the cut out on the bar. I will keep a watch on you rig build up to see how you go, what size winch did you go for 10000lb or the 12000lb ? Cheers Brett
just ordered a tg thompsen solenoid and a 500 amp constant isolater.. got new 35mm2 cable and lugs comin thro work...
so i can give the aldi winch a make over b4 it evan goes in ... bill so far
4.3ton single line pull.. 5.5hp motor winch.... $399 9500 LBS
thompsen solenoid................................... $ 79
500 amp 12v isolater................................ $ 59
mose well add a high crank battery to the bill just for kicks.. got a "Allrounder" start and deep cycle combination battery , single battery set up
knocked up the winch insert..
cheers butane... i"m a boilermaker/welder 1st class here.. has its advantages..Last edited by butane8; 27-10-2012, 06:29 AM.[u][i][b][color=#0000FF] ..lets take her out for a spin... butane[/color][/b][/i][/u]
Brett,Originally posted by BrettM View PostHi Hazza, I have consider making more drawers to sell but I think the cost of shipping them around the country would make them a bit expensive. If you can weld then I would say have a go at making some, but if you can not weld and would been keen on a set I could make them but you would need to price and organise the transport. Mine are just made out of MDF screwed to a steel frame (20mm RHS) and the drawers are 16mm pine, the handles are stainless steel which cost me $40 of eBay the drawer slides I got for free and I'm not sure what they cost. Cheers Brett
You are right sending something of that size and weight across the country would be far too expensive.
I can weld and have a stick welder (no mig unfortunately). If you have some plans with measurements and happy to share I would love to have them to have a go at making a set.
HazzaSilver 120 Series Diesel GXL 2009 with Option Pack 2, king Springs 2" Lift with 'H' front spring, MT ATZ 4-RIB, Dual Battery, Deluxe ARB Bull-bar, Winch, Towbar, Anderson 50 amp plug at the rear, Weather Shields, Bonnet and Head Light Protectors, Rubber Mats inc Cargo mat, UHF Ariel, Portable Uniden UHF plugs into areal, On-board ARB Compressor, Brains Black Box TG150 Protector, Rear Black Duck Seat Covers.
Hey Brett,
Hows the rig coming along?[B]Prado 120 Series Build; [/B][U][url]http://www.pradopoint.com/showthread.php?24346-Desert-Dueler-120[/url][/U]
Here is a few pics of the latest fabrication job on the prado, still need to cut the alloy plate which is tomorrow's job.
[img=http://s18.postimage.org/oyrihsdt1/image.jpg]
[img=http://s8.postimage.org/4n55axlcx/image.jpg]
Cheers Barry. Here is some with the alloy plate on
[img=http://s7.postimage.org/z8kfap3ev/image.jpg]
[img=http://s7.postimage.org/uuubhtmdj/image.jpg]
Did a trip up to the Pinnacles on the long weekend
[img=http://s23.postimage.org/4xu79p6xj/image.jpg]
Prado went in to Toyota to have a leaking rear main seal replaced, while they had the gear box and clutch off they skimmed the fly wheel and replace the bearings in the clutch ( made the clutch so much softer ).
