Been a bit slack on posting updates, so going to add some info on what been added to the car in the last year or so.
Starting with an update on the suspension height. 22 months ago after having the lift fitted the heights were:
The rear is likely much higher as they are the 300kg springs.
- Front: 810 (+45mm over standard)
- Rear: 850 (+70mm over standard)
- Front: 799 (+34mm over standard)
- Rear: 842 (+62mm over standard)
