  • Woo hoo, next week order!
    • Originally posted by berniebgf View Post
      Yep.
      Here are some pics of the new telescopic pole with 27W LED light fitted.
      It raises this far above the roof rack
      • AMTS, this product has come along way since the first prototypes.
        Looks like a quality custom product, can you please let me know when I can put my order in ASAP.
        I've been holding off getting the Kaymar unit for yours, thanks for all the hard work your putting into it.
        This is going to be a big seller.
        regards
        Bernie.
        • This has come a long way Andrew, Well done. I really like this pole design and that locking pin looks much sturdier. What is it?
          My Grande Build Up
          [url]http://www.pradopoint.com/showthread.php?25867-My-04-Grande-Build-up[/url]!
          My Hilux Build Up - R.I.P
          [url]http://www.4wdaction.com.au/forum/viewtopic.php?f=22&t=121302[/url]
          • Sign me up for the first pole, that design looks much better than the paint pole!
            I haven't forgot the mock-up antenna mount, just a bit time constrained at the moment...
            • Hi Andrew. I received the wheel spacer and light pole bracket on Friday and fitted it same day. Very happy with the spacer and I look forward to placing an order for the new work light pole assembly soon as you have stock. Like everyone else on this thread I am impressed with the quality of gear you are turning out and appreciate your help finding solutions to our common problems.
              Paul
                AMTS, this product has come along way since the first prototypes. Looks like a quality custom product, can you please let me know when I can put my order in ASAP.I've been holding off getting the Kaymar unit for yours, thanks for all the hard work your putting into it.This is going to be a big seller. regardsBernie.
                Hi Bernie,You can email me anytime but no monies taken until there is something available.
                • Originally posted by jhiace View Post
                  Cheers Josh. It is a nylon tip screw. This is the final piece of the puzzle.
                  • Originally posted by rwo View Post
                    Yes, both poles are 3mm walls. I brought it in to work and the colleagues were commenting on the heavy dutiness of the pole. It definitely feels solid in your hands.
                    Read somewhere that you were going on a trip soon. That's OK. I'll get the 120 version made and then tweak it for the 150 if necessary.
                    • Originally posted by Prmiller View Post
                      Hi Andrew. I received the wheel spacer and light pole bracket on Friday and fitted it same day. Very happy with the spacer and I look forward to placing an order for the new work light pole assembly soon as you have stock. Like everyone else on this thread I am impressed with the quality of gear you are turning out and appreciate your help finding solutions to our common problems. CheersPaul
                      Thanks Paul. Got to keep the grey matter alive and kicking.
                      • Hi Andrew,
                        Is the light pole available separately from the Tyre Spacer?
                        If so, what is the cost with Freight to Lara?
                        BTW, you have done an excellent job - better than anyones i've seen.
                        Also, keep me in the loop on the HF Reverse lamp / Tyre Spacer with the Telescopic lamp for the 120's, as I want to replace the one that was done 4 years ago, which
                        doesn't include a telescopic camp light, and the Codan HF Aerial mount now sits too high, by about 100mm or so.
                        I want to keep my vehicle height, under 2.1 if possible.
                        Will send you a photo next week of my current one.
                        Stuart
                        Stuart Trevena
                        [COLOR="#FF0000"][B]2008 Prado GXL D4D 3.0L T/D 5 Speed Auto Colour: Dune with loads of Extras[/B][/COLOR][COLOR="#0000CD"] [B]and 2015 Tvan MK4 Murranji Offroad Camper[/B][/COLOR]
                        • Originally posted by PradoGXL08 View Post
                          Hi Andrew,
                          Yes. There are 3 items:
                          1. Spacer
                          2. Light pole bracket
                          3. Telescopic pole
                          Low $20
                          Stuart
                          You did get the newer Codan 3040 antenna?
                          • Good Afternoon Andrew,
                            Could you please provide Price to supply the following:
                            1) 1 Only Telescopic Light Pole (NO Light)
                            2) 1 Only Bracket to Suit.
                            Please include Postage to Lara, Vic 3212.
                            Or I can send you the light, that I plan to use for you to mount, then ship back. (Might need a larger mounting area)
                            FYI, I have a ML25 Superflood http://www.monsterlights.com.au/ml25.htm
                            from Monster Lights here in Carrum Downs
                            Also, as for the Codan 2040, no I didn't, given the price.
                            I await your reply.
                            Stuart
                            Stuart Trevena
                              1. Spacer $62
                              2. Light pole bracket $40
                              3. Telescopic pole $130
                              Between $20-25
                              FYI, I have a ML25 Superflood http://www.monsterlights.com.au/ml25.htmfrom Monster Lights here in Carrum Downs
                              Nice lights. They are very slim. The existing mounting area is fine. The mounting bracket looks the same as the 27W LED worklight I bought from ebay. Seller is Sunyee-au.
                              http://www.ebay.com.au/itm/330675082...84.m1439.l2649
                              The light is awesome but perhaps not as much spread as the ML25. Will take a pic of mine one night.
                              I await your reply.
                              Stuart
                              Perhaps you need a knockdown bracket to suit for around town driving. Is your HF usage only for trips?
                              amts
                              Ninja Poster.
                              • Andrew
                                Can I please order the following for my 120
                                1. Spacer $62
                                let me know how to pay, and I will p/u from Mawson Lakes if that is okay.
                                cheers
                                Dennis
                                Ag Nomad
