Recovery points that fit ARB bull bar
    If you used both at once using an equaliser strap it would share the load and less chance of it breaking I assume. Then there is the shackle due an more potential flying metal.
    BiLLz0r
      Originally posted by pradogang View Post
      My recovery points were fitted by TJM at Brendale and they just bolted straight on. The invoice does not give a brand name but as amts said in an earlier post they are for a 150 series.. You can call them on (07) 3490 6900 for more info.
      Didn't do Gunshot, I did the chicken track. Haven't hit any roos yet but the bar seems quite solid.
      cheers
      Jim
      Thanks for that mate, i have the roadsafe ones bolted to my chassy at the moment and looks like you would have to use a bridle strap as the front of a 120 isn't very strong looking.
        Im just about to order a Arb delux bar with a smitty built winch and seen these recovery points somone had on this site, anyone know what they are as ive only seen the 150 type ones like on previous page.
          Originally posted by Brad_kosij View Post
          There not rated recovery points there tie down points and arnt rated for recovery
          Im going out on a limb here and saying that I think you are wrong. The ones on the chassis, yes they are just tie down points. But the ones built into the bar are recovery points.
          Travelling Panelbeater
            Those used to be mine but I sold them with the ARB bar. They are the original ARB bar mounts custom modified by a certified welder with the addition of extra strengthening ribs and with the ARB loops replaced with 12mm steel. They are not commercially available.
              I'm sorry Whitey but that limb is going to break on you
              The OEM ones are only tie down points on the pre-2006 model. From 2006 they are towing points not tie downs as stated clearly in the manual. The official line from ARB is that the ARB loops are tow points and can also be used to attach your winch clevis on a double line pull (but you could do that with the 2006 OEM points anyway).
              I have also been told that the 150 series tow points (check out the Roadsafe website they are not 'recovery' points either) will only fit the pre-2006 model unless you remove the OEM tow points. Personally I can't see the point in removing the OEM tow points to fit aftermarket tow points.
                Yeh, they look good.. Hadn't seen them before..
                  I wonder how many times this subject will go around in circles before its ever resolved
                  Tie down points, tow points, recovery points, there all just words that really don't mean much in reality.
                  Take the loops on the ARB bar, ARB say they are not recovery points, but you can use them for winching, which is a recovery isn't it? What they should say is not a snatching point if that's what they mean.
                  The fact of the matter is that there is NO standard for what a recovery point is meant to be, so in reality what ever you attach your strap to is a recovery point, whether that is safe, or smart or anything else is another story.
                  In its simplest form here it is, if your "recovery" point has a WLL or an SWL marked on it then the point is rated to that load, the safety factor for that load is upto the individual manufacturer as there is no standard. The fact that point is rated doesn't mean that where it is bolted to the chassis will withstand that rating, once again there is no standard that requires that sort of testing.
                  If your "recovery" point doesn't have an SWL or a WLL marked on it then it isn't rated. That's not necessarily any worse than having a rated point that's bolted to an innapropriate part of the chassis though!
                  So like most things in life where there is no definitive answer it all comes down to common sense (which isn't that common nowadays) and ultimately the thoughts of the people involved in the recovery.
                  Personally I am working towards being able to produce the ultimate in fully rated recovery points for the 120 Prado with an ARB bar. Research is cheap enough but producing them will be a VERY expensive investment on my behalf. Hopefully next year I will be able to put out a proposal for the production of these recovery points and depending on demand I may go ahead and produce them.
                    Yours look like the Outback Ideas ones Jim, I know TJM used to stock them. I have seen an identical copy marked as Boss4 on eBay (just search on "Prado Tow Points" to find them). The Roadsafe ones have a longer hole where you attach the shackle or strap and they are yellow. I'm not 100% sure if the Roadsafe ones will fit on a 120 but I believe they use the same bolt pattern as the red OI or Boss4 ones.
                      Sorry to burst yoru bubble, but I have been through this. It will NOT FIT all 120s.
                      Jims (PradoGangs) solution of using the recovery points, will ONLY fit an early model Prado 120 ( the one with the chasis tow loops unit welded underneath the chasis), This is a great soluton as TJM Brendale have shown. I would do this if you have an early model prado 120.
                      IF you have a late model 120 ( with the chasis tow loops unit welded through the chasis) they WILL NOT fit (without cutting.)
                      See here. http://www.pradopoint.com/showthread...l=1#post386618
                      Robert
                      [B]Robert
                        Robert
                        That's what I said - the change was in 2006.
                          Yes mate the bridle strap is the way to go!
                          • #28
                            Sounds good Andrew.
                            Troy
                            2005 Toyota Prado Grande 3.0 TD - ARB Deluxe winch bar, Avenger 9500lb winch - nylon rope, Safari Snorkel, DP Diesel Chip, Lightforce HID 240's 50w, Oricom UHF, Bushranger Mud Tamer mats, Toyota Genuine Tow Bar, Toyota Genuine bonnet protector and headlight protectors, ARB Roof top tent and awning, ARB dual battery system with Red ARC and Optima deep cycle battery, Max Trax, ARB Compressor and Rear Air Locker, Waeco 50L fridge/freezer.
                            • #29
                              I'm in. 1 set please. PS Trekky's ones look, well, OVERATED!!!!!! (They are not copyright protected AJ).....just saying
                              • #30
                                So AJ these should be in production by the time the 2015 GTG is happening then? Should have the ARB bar on by then so these will be a very usefully addition.
