Auto trans service
  • #46
    Mate - Stuff Toyota, unless your under warranty.
    Find a transmission specialist. They have all the right gear to do that job.
    • #47
      Yeah agree with mackayvx on this one. You will pay double the rate per hour (or close to it) and as mackayvx said, if its out of warranty then take it to the specialist. I know a dealer ship here in Sydney that send their vehicles out side of the toyota work shop to get any transmission work done, including manual boxes...........Cheers Steve
      • #48
        The transmission plan will hold around 3.5L so 4L to drain and refill sounds right. Drain 3.5L, fill 4L, let it circulate then open check plug to correct level.
        • #49
          Have Factory Extended Warranty till 2015 or 150k, that's why I've been going
          To Dealer. Fair enough with the 4 litres then, but there was mud all around trans pan/drain & filler plugs,
          Still the same after service, I'd expect them to be wiped clean after service, so I doubted they,d done anything.
          Will take your advice & go pro trans specialist
          D4D 09 OME Suspension/ARB Winchbar/Safari Snorkel/IPF Spotties/Cooper ST Maxx Tyres/9000LB Tigerz11 Winch with Dynema Rope/GME Remote head UHF/Sheepskin Seat Covers.....Next on list Dual Battery Sys...In Dash GPS...Rear Diff Lock
          • #50
            Id be asking them how did they drain or refill the transmission when there is still dirt and crap on the bolts etc. See what the bullshit excuse is ??.........Cheers Steve
            • #51
              My Toyota Dealer quoted $350 for Gearbox Fluid flushed and changed, Told me they the flush the torque converter properly etc. I suppose its not to bad going considering the cost of Trans Fluid. They also quoted me $190 for both the front and rear diff oils changed. I always have gone to Morley Galleria Toyota in WA for any work that I haven't been able to do myself and find they are really good to deal with and not to overly priced considering it's a dealer
              Black 120 Grande 2003 "MY4BEE", 4L V6 Petrol 4SP Auto, BFG All Terrain 275/65/R17, Rola Racks, ARB Deluxe Bar, AirbagMan OA6011 Airbag's, Bilstein Shocks, Front King Coils, Eclipse BEC108 reversing camera, LightForce Spotties, Ironman Awning, ARB Outback Storage Drawers, Uniden 80ch UHF, Waeco CFX-65DZ, Oztent RV3.
              [URL="http://www.pradopoint.com/showthread.php?29118-MyPradoGrande-s-120-V6"]My Rig Build Up[/URL]
              • #52
                Hi I just requested some tech info from a work contact at Toyota regarding how to check the 750 auto without the intelligent tester to give the Auto temp and in the info sheet it has the following refill amounts,
                Removal and installation of oil pan (Including oil drain) 1.7 litres.
                Removal of transmission valve body assy 4.3 litres
                removal of torque converter assy 5.4 litres
                so just removing the pan to drain 1.7 litres is not a great deal of fluid changed!
                Cheers Rick
                IMO flushing is a waste of $$$.
                I used to use a machine to flush them.
                We used to flush 15litres.......
                It goes in one end out the other.
                So it's still not getting it all out.
                There's nothing to separate the new from the old, you cannot run it dry.
                So what's coming out is also new oil that just went in mixed with the old stuff.
                There is a drain bolt there for a good reason, drop it out and refill is quick, easy and cost effective.
                Yes it doesn't all come out, but either does flushing......
                Just drop it more often if you want it cleaner.
                A change usually gets 5 liters out.
                That's pretty good. Just my 2 cents or so?
                • #53
                  There is definately more than 1.7L of oil in the pan. The pan holds nearly 4L with the engine off. 1.7L might be the volume with the engine running and oil circulating.
                  • #54
                    Reluctance to shift into overdrive
                    Originally posted by johnnydrama View Post
                    I have noticed recently that the gear box tends to hold onto a gear longer, or be reluctant to flick into overdrive. To get it into overdrive i often had to flick it out of "D" into "4" and then back into D and that would make it kick into overdrive.
                    Hi johnnydrama,
                    I have seen this in my '05 5speed petrol too, whilst towing my caravan. Not very often, but enough to stand out as being different. Have you experienced the problem since replacing your trans fluid?
                    Andrew
                    • #55
                      Originally posted by ah197331 View Post
                      Hi johnnydrama,
                      Andrew
                      I get that as well, not towing or anything (mine's a 09 diesel). Happens more when the car is cold(ish). On the freeway the speeds are max 100km/h so when you drive around there it takes forever to jump into overdrive. Doesn't happen when warm, might be the way it's supposed to be?
                      • #56
                        The only time I've seen the issue is warm, or maybe it could be the first stage of trans fluid overheat?
                        • #57
                          Is it the fifth gear change or the lock up torque converter not locking up till it gets to a certain temp. I know my wifes auto in her Toyota wont go into 4th (speed auto) until a certain temp.. Not sure what the temp is. My old VL commodore wouldn't go into overdrive until 75k which was too lower speed, use to drone. Havnt noticed it with my 5 speed auto as mine is warmed up by the time I get to the main road (10 minutes of roundabouts and crap)......Cheers Steve
                          • #58
                            Another PP member and I are doing a complete transmission flush and changing all the diff oils plus crankcase this Friday. If anyone wants any 'rough' pics or measurements please get in touch. Should be an interesting day!??
                            • #59
                              Yes, pics please for the transmission flush.
                              • #60
                                Hi johnnydrama,
                                Andrew
                                Sorry Andrew - haven't been around much so haven't seen your question.
                                Post-Transmission fluid change I did still see the reluctance to drop into overdrive - but it did happen a lot less. i.e. I'm pretty sure i only ever see it when towing now - whereas before - I'd see it when cruising without the camper as well.
                                2008 GXL Option Pack 1. TJM T13 Colour coded Bullbar. Lightforce Striker 170's. 2" Bilstein + King Springs lift. Tyredog TPMS. Uniden UH7760 + RFI CDQ5000. Brains Transfer Case Bash Plate.
