My Battery is still going in 05 120 V6 Grande. It's a Panasonic. I bought the Prado 2nd hand 3 years ago thinking it was the original battery & have been waiting for it to fail ever since but to this day no problems at all.
How long did you get from the OEM battery?
05 Prado Grande 120, Champagne Mica, Sovereign Bullbar, Toyota tow bar, Hella Rallye FF 4000 compacts, BFG A/T's, Stebel air horn, Front recovery points, Piranha twin battery setup, ARB compressor under bonnet, GME UHF & antenna, King KTFR-101 front springs, Fire extinguisher, Electronic rust preventer
My original battery [Nov-o5 build] is still going strong in my old Peugeot 504 where it has been residing since I took it out of the V6 prado before a big outback trip in June 2010. BUT I have today just put in the 3rd battery into the Prado since then! 1st one expired 4 months after CSR trip; 2nd one a heavier duty 650 CCA has lasted 33 months and died suddenly- also has done a lot of outback work. 3rd one is a 550CCA AC Delco recommended by the auto sparky [ who also did a current leak test at the same time]. Fingers crossed for a long life for it with no trips planned. part of the problem I suspect is that the Prado often sits in the garage for most of the week and often only gets 2 20 km runs on the weekend. Neil
Originally posted by gogo543 View PostI replaced my dead OEM with GSYUASA 760CCA during the weekend.
the length of battery is longer than the original tray comes with OEM.
What do you guys usually do? where can i find a tray which can hold this new battery?[url=http://www.myswag.org/index.php?topic=12264]My Prado[/url]
I replaced my OEM battery over the weekend. 6 years and 77,000kms. The battery was still going fine, but Im going on a big trip in a few weeks. I replaced it with a BOSCH S5 'Mega Power Silver'. I got it for less than half price through my work. 165RC, 92AH, 760CCA. Fits perfectly.07 White GXL D-4D & 6 Spd Manual. Sovereign Bar with 3 LF 240's. RedArc dual battery system. Icom Pro 440N UHF, Hilux washer upgrade, Ironman 2in lift and 4 new injectors
Rig Build Up [URL="http://www.pradopoint.com/showthread.php?27854-Fronty-s-07-GXL"]http://www.pradopoint.com/showthread.php?27854-Fronty-s-07-GXL[/URL]
Louis
Could you please advise where these batteries are available from?
thanks Glenn
Bought my 06 GXL new and the battery lasted just under 6 years. Very happy with that![INDENT][CENTER][SIZE=4][B][URL="http://pradopointgtg.org"][COLOR=#000080]PradoPoint GTG 2014 - [I]Iconic High Country - Victoria[/I][/COLOR][/URL][/B][/SIZE][/CENTER]
[CENTER][SIZE=3]Big Thanks to Our Sponsors - [/SIZE][SIZE=4][COLOR=#ff0000]ARB 4x4[/COLOR], [COLOR=#800080]Dobinsons Springs and Suspension[/COLOR], BCF, [COLOR=#008080]Terrain Tamer[/COLOR], [COLOR=#696969]ORU[/COLOR], [/SIZE][SIZE=4][COLOR=#ff8c00]Maxtrax[/COLOR], [COLOR=#0000ff]Traxrax[/COLOR], [COLOR=#800080]Brains[/COLOR], [COLOR=#ff0000]Redarc[/COLOR], [COLOR=#008000]Opposite Lock[COLOR=#222222], [/COLOR][COLOR=#0000ff]Kaymar, [/COLOR][/COLOR][COLOR=#ffa500]Hema Maps, [/COLOR][COLOR=#ee82ee]pure-sense, [/COLOR][COLOR=#696969]Bushskinz, [/COLOR][COLOR=#ff0000]Piranha Offroad [/COLOR][COLOR=#800080]High Country 4x4 [/COLOR][COLOR=#222222]& [/COLOR][COLOR=#808080]Century Batteries.[/COLOR][/SIZE][/CENTER]
[/INDENT]
Bought my prado D4D new Sep-2007 (built May 2007) with now 194,937km on the clock & had to buy a new battery today as it only just started this morning
I reckon 7yrs & 10 months is a good run for OEM battery (GS Nippon Denchi 105D31L-MF)
Replaced it with a Century N70ZZL4WD And got it for $218.
CCA @ -18°c: 760
RC @ 25°c: 185
Weight (kg): 22.50
Polarity: C
Length: 306mm
Width: 171mm
Height: 201mm
Total Height: 222mm
Now that i have bought the battery as per usual seen the same battery cheaper else where!!!... Dang!
Don't let Toyota fit one of their replacement batteries - they leak when used off-road. I got 11 months out of one.Dave
