Surging/stuttering feeling off throttle
    Can't drive it the way it is dispite the experts saying nothing is wrong.........computer says no!
    I have ordered a crank able sensor now $98 from blood Toyota Geelong. Interesting the price varies by as much as $100 if I purchased it from Melbourne.
    Now as far as an air leak issue, I would have thought it would have occurred at any revs not specific to that 1800 - 2000 rpm. It almost seems the gentler you drive it in that range the more the issue. If you load her up and accelerate hard, you don't notice the issue as much.
    I thought I would disconnect the gas computer completely to see if it was a gas Ecu induced problem and ran it on petrol only for three tanks (1500km) after resetting the EUC. No change.
    Anyway it will be in Wednesday so we'll see. Has anyone fitted a crank position sensor?
    2006 Prado GX silver, 6 speed manual, LPG, ARB Delux Winch Bar, IPF's, snorkel, UHF, 2" Lift with Dobinson Coils, Poly airbags, Bilstein Shocks, Pacemaker Headers, Cooper ST's, Piranha Dual Battery System.
      Fitted the crank position sensor.....No change. Crappy job with having to remove the aircon unit to get access to it.
      Checked the resistance between the old and new before I put it in. There was a difference 2.7 to 2.15 ohms, both within the specs.
      Also checked for vacuum leaks on the inlet manifold using soapy water but I could find any.
      The search continues, I'm open to suggestions
        Wal01. Please tell me you fixed it. I have nearly the exact problem. I have a hilux with same engine on LPG / petrol. Have done many things you have to try to fix with no result.
          Is there a resolution to this problem? Mine is doing similar.
          05 Prado Grande 120, Champagne Mica, Sovereign Bullbar, Toyota tow bar, Hella Rallye FF 4000 compacts, BFG A/T's, Stebel air horn, Front recovery points, Piranha twin battery setup, ARB compressor under bonnet, GME UHF & antenna, King KTFR-101 front springs, Fire extinguisher, Electronic rust preventer
            No ever fixed it. The issue solved itself or I got used to it. I ended up selling the poor old girl with 367k kms on her. We did a 5 week trip towing the van as a last horah and she ran like a dream, regularly sucking 30 plus L/100kms though through NSW. The only thing I did do which may have assisted was disconnecting the battery and connecting the positive and neg lead together for 12 hrs to completely discharge the ECU. Re connected it and ran solely on petrol for 3 tanks to allow the ECU to learn again. Theory was but running on LPG whilst in the learning phase, the ECU learns the wrong values to run correctly. I bought a new 150 diesel a couple of months ago and now I’m dealing with an auto that down changes all the time. Try the battery method then running on petrol. Good luck
              Mate, not relating to original topic, but that 30+l/100km is on petrol or lpg? And how heavy is the van being towed?
                Ive towed a 16ft Expanda (about 2T) with my Petrol and it used 21l/100km on average.
                FWIW, I also towed the same van with a D4D prado and used 17l/100km average.
                30l/100km seems way too high.
