  • Got it back from the panel beaters (neighbour owns a panel shop) after getting a new rear bar fitted. Asked him to do a small mod when he painted it. I think it turned out ok.
    • Originally posted by D4D View Post
      Took me a little bit to notice what he did Haha. Looks good. Been thinking of doing the same myself.
      • Did you do that in gloss or satin?
        Just thinking of potential scratches.
        Greg - 08 D4D Prado,
        • Originally posted by Corigator View Post
          Satin
          Day time shot
          • Replaced the second Polyair bag in 2 years. The right side went at 6 yrs old and the left at 8 years old.
            • Fitted 2 usb charge thingys 1 full live 1 ign live.
              fitted a set of cheap ebay hid 100w 7 inch lights
              Repaired the horn after 5 years not working.
              Turned out to be faulty power feed from front fuse box.
              Ended up installing new relay with fuse by the inside fuse box. Located the trigger wire from steering wheel.
              Located the horn feed wire. Took power from main feed at bottom of inside fuse box, linked feed and power for relay together, used the trigger from horn onto relay earth,
              And fed out going power to horn feed. Horn now working as should.....apart from that strangled chook sound, Stebble air horn in the mail. Will be fitted as soon as it arrives
              • Crawled under to change the clutch slave, found the LH CV oil seal leaking diff oil... Added to the repair list.
                • Spent $2100 at the Melbourne 4x4 show.
                  Safari snorkel
                  Redarc Smart start Isolator and 52mm EGT/Boost/ Oil Temp gauge ( 3 in 1)
                  ARB Under body plates
                  Diesel care 2nd fuel filter
                  Flashlube Catch can Pro
                  All fitted
                  • Added a front hub to my parts-to-order list. Attempted to seperate the bearing from the hub. Did. Not. Work. Well. now she just sits at work in pieces waiting for parts. Hopefully can get it finished tomorrow. Then I'm getting a new driveshaft
                    • Finished my wheel bearing and replaced a driveshaft. She drives like new again
                      • What was the symptoms for the front bearing Wtrxprs007? I have a squealing noise and occasional clicking when under load. If it was just clicking I would of thought CV for sure. But this is in a straight line only and as said, only when under load. If I idle it goes away. Put it in neutral and rev, nothing. It sounds very much like a bearing.
                        Sent from my iPhone thingy
                        • craigm, just jack up the front wheels & feel the top to bottom movement (push/pull the top & bottom of the tyre)
                          mine had only 90k on them and they were stuffed ( previous owner had done a few water crossings)
                          mine had no noise , no issues just notice the play in the wheel while on the hoist
                            hmm, you issue sounds weird. I'd check for anything rubbing like the backing plate behind the rotor, not sure.
                            How I found my wheel bearing was just one day I had the car in the air, and there was a LOT of play in the wheel when you move it at 12 and 6. Weirdly, I had no noise at all before I found it.
                            wouldn't think a bad bearing would be squealing or clicking when driving though
                            • Did some hard work today, but had to down tools because there was a delivery!
                              Drifta drawers turned up at the front door, installed them in notime. Still have to do the side infil pieces yet.
                              Very nice fit, and easy!
                              • Installed the HKB voltage booster and immediately saw an increase at idle from 13.7v to 14.4v. Very happy with this.
                                Terry
                                Canberra
