    Replaced the clips on the front door panels. The lower ones were pretty brittle hence the rattling. Trust Toyota to have 3 different coloured clips.
    Hi Bushbasher, would you have part number for those clips, mine are rattling too, temporarily I put in some tape to stop it, but would like to replace eventually, and since I will be getting some spare parts, might as well get these too.
    • N/A
        CASE, METAL Toyota 5373160071 Ship in 5 days (approx) 48.82
        Plus $38 postage from Amayama (UAE).
        Thanks for that. I wonder what the difference is between the 70 and 71. Do you know if all four parts superseded?
        • Originally posted by Borec View Post
          only the said part replaced the old piece. there may have been some revision in material or something.. someone with both old and new parts could tell us
          • Given the dust that came with it it's been sitting on a shelf some where for ages. There's heaps of cut-outs to clear other bolts and fixings so maybe they changed that a bit. They still didn't get it right because one cut-out was too small.
            • Whilst I was putting everything back into the right side I noticed some rust starting to build up on the battery tray. This is my second tray for the aux - BT64. Been in for about 2 years. So I got to it with wire wheel, rust prep, primer and black rust rid paint. Let's see how long it lasts this time.
              • Impressed with the Rhino rack Backbone system so over past few days have knocked up a similar version. Got a full length alloy rack off gumtree for $300 so removed the original 3 bar setup and made new brackets to fit onto roof. Then machined up 2 lengths of aluminum angle to bolt onto brackets that the new rack can be fixed to. Method in my madness because want to knock up a boat loader so this way will be easier to swap between the two. After machining slots so could reach the nuts for fixing went a bit further and machined sections out to add a bit of bling to the plain angle.
                Deciding now whether to keep alloy or powdercoat black.
                • Originally posted by sparksy View Post
                  You could fully polish it!
                  Seriously, nice work. Those of us with only angle grinders and drills are very jealous.
                  • Thanks Dave
                    The rack is pretty well made but the brackets that were supplied with it to fit onto roof were
                    Cr*p.
                    sparksy
                      http://www.pradopoint.com/showthread...l=1#post517417
                      • Oil and filter change in preparation for the bush trip in 3 weeks time. Got the camera up the hole and sump screen all clear. New in-between filter too.
                        • Fitted the new ultra gauge to replace my dead scanguage and got the Transtemp gauges working.
                          • Last weekend removed the old recovery points (remembered those radiator bolts are a pain) and waiting in anticipation for AMTSparcel to arrive...
                            And it arrived today, another quality product from Andrew
                            Install them this weekend, happy having these up front if a recovery ever required (but hey it's a Prado)
                            Cheers kim
                            • Filled the 120 series
                              180.74 liters
                              • Originally posted by Auscanclan View Post
                                180.74 liters
                                yep
                                i did that early this week 180.24L (filled to the brim) still had 35km to go on the MFD !!
                                the most i have put in was 185.4L ( filled to the brim) only had 6km to go on the MFD !!
