  • Looking good Helmuut. Was thinking of doing the same. Using a deck of cards is a great ides.
    • Looks great. What type of paint did you use.
      • Pretty sure it was just rustguard paint from bunnings.. All up cost me around $50 for black, clear and a deck of cards 👍
        • Gave the auto transmission a full flush with new fluid. Pretty easy job with a bit of pradopoint collective knowledge. Drives much smoother now, hardly notice shift changes, and changes when it should. All up cost about $185.00 including buying a Tom Thumb pump to refill easily. Old fluid was black as coke and a bit of a burnt smell. Car has done 215k but not sure if it has been done previously as I bought it at 200k, I suspect not. Used 12 ltrs Penrite ATF LV, was coming thru nice and clean by the time the last litre went in
          • Lightbar installed.
            1979 BJ40
            1992 FZJ80R
            1997 HDJ80R
            2005 GRJ120R
            • Redback extreme exhaust. 3 inch full system with optional muffler delete pipe. took 20 minutes to remove old system and 30 mins to install the new one. I only notice the sound difference but nothing in the power department.
              • Gave the Old Girl a Polish
                • Originally posted by mikenzaa View Post
                  spew mate
                  11/06 kdj120 gx wide body auto
                  • Pulled these suckers out, to put seat back in, what an epic. Click image for larger version
                    • Today got my car back with a brand new 1900 rhino platform
                      and kaymar telescopic rear light that mounts behind spare wheel 👍
                      As soon as I got home I pulled it out and gave it a coat of black. Black is definatly better 😏
                      • Helmuut that black finish sure does look the goods. Great job and thanks for sharing it.
                        • Last week finally got the alloy rims coated to match the bull bar. Also took the muddies off the steel rims and had them fitted to the alloys with letters to the outside.
                          • Played in the mud yesterday at Julimar. Wasn't going to go in and then sank it in the ooze.
                            • Got the 190k km service done today.
                              While they were at it and in combination, the leaking front crankshaft seal along with the pulley/harmonic balancer both got replaced.
                              Troy
                                Bloody hell Dave
                                You've gone and mucked up those great looking wheels.
                                Troy
