Cracked inner guard repair and reinforcement options?
  • #31
    I agree with Bushbasher, a good panel beater could easily repair the crack and reinforce the area, it's a very basic repair. I regularly carry out aircraft structural repairs, to repair this I would stop drill (drill a hole 4-6mm) just beyond the end of the crack and rivet a repair doubler over the top. The stop drill reduces the stress at the tip of the crack minimising the chance of it propagating. The repair doubler is to redistribute the load over the cracked area.
    As it is mild steel, welding the crack and then welding a suitable doubler would also work. Access is reasonable good so the cost should be only a few hundred dollars at any panel beaters. Aesthetics is not a big issue are the area has limited visibility and could be covered with sikaflex to give a smooth finish.
    Whilst replacing the whole apron is the ultimate solution this is a very big job and would cost LOTS for no real gain. There is also the problem of maintaining alignment of everything when it is pulled apart. Time to repair should be 1-2 hours, to change the apron 2-3 days, big differance in cost.
    • #32
      Thanks for that mate, first (and only) quote I've gotten so far started at $700 for a basic weld repair to the crack but after i laughed at it they said they could re-inforce both sides and repaint it for a total of $800. I won't be going to that company just out of principle with their outrageous original quote but surely it shouldn't be anywhere near that much. I don't even want it painted, I can do that.
      I've put in an enquiry with Amayama so hopefully they may be able to get the parts even though their not showing as available on the website, I've also emailed Toyota Australia but would be amazed if i get any help out of them.
      • #33
        Has anyone got the install instructions for the repair kit?
        • #34
          Fitted plates today after removing fender and battery, removing bolts from fuse box and fuel filter. Most holes drilled from outside, some had to be done from inside the engine bay. Stainless M6 x 16 bolts, nuts, washers and spring washers from Coventrys.
          • #35
            Before putting fender back on I discovered 2 cracks in the frame brace:
            • #36
              Always great to have pics of what lies underneath.
              Appears to have been there for a while looking at that rust in it. Got a pic of the other side too and what you did regarding the missing piece?
              • #37
                Haven't done right side yet. That will wait as I have other things to do.
                • #38
                  Alright. Hopefully something can be done about that missing piece
                  • #39
                    I have the crack too, but did a quick search on the parts (from the missing french link from the previous posts - renforts-ailes-kdj120-kdj125) and came up with this) If you put that in google you will get quite a few results, mostly in french, but there are pictures too
                    http://www.n4-offroad.com/?Front-fen...-J12-6&lang=en
                    http://www.euro4x4parts.com/parts/la...373460050.html
                    here is the fitting kit
                    http://www.euro4x4parts.com/parts/la...1671a0614.html
                    I wonder if the parts sold by Amayma/Partsouq are the same as the ones sold by the french mop, as the price difference is pretty steep. From pictures they look the same, however cannot get the right bit from Amyama/Partsouq, nor the fitting kit.
                    Borec
                    • #40
                      I know this tread is in the 120 series section, but are we talking about 120 series of 150 series?
                      4WDriver since 1975, current 4WD, 2009 GX diesel auto 150 series, fitted with ARB bullbar, snokel, dual batteries, rear draws, water tank, mud tyres, side steps, 50mm lift & roof bars. Tow a Olympic Champion XPack caravan, travelled a lot of Australia, past big trips in 150, August 2010 - Hay River Track NT, July 2011 - Kimberleys and WA, July 2013 - Canning Stock Route WA.
                      • #41
                        Most of it is about 120, but I believe somebody mentioned the cracking appears in 150 too (the parts mentioned here are for 120)
                        • #42
                          Yes, the parts are the same. I bought them in Euro4x4parts and a friend bought in Amayama. Much more cheap :-(
                          Part number for diesel 4 door 120 models:
                          53734-60050
                          53731-60070
                          53733-60040
                          53732-60060
                          • #43
                            Thanks for confirming that Newton
                            • #44
                              This 120 long term cracking.
                              Both sides.
                              • #45
                                That's a bit of a worry, ####. Is that yours?
                                Greg - 08 D4D Prado,
