you can go down the road of fitting up a drop cradle kit to the front, which gets a minimum 4-5" of lift, then you can go another 2" on top of that if you already have a 2" suspension lift now. then for the back, get some 5-6" coils from the states (cos no one does them in aus) either from a 4th gen 4runner, or even FJ's and maybe some coil spacers to suit if needed.
not sure, but snake racing did a drop cradle kit for the lux with no cutting of the crossmember. if superior still do the BTV ones, i'm pretty sure they come with a replacement extended knuckle to suit the extra height.
with the drop cradle kit, you shouldn't need upper control arms, as its almost like a body lift rather than a suspension lift.
i looked into the pro comp drop cradle kit a year or so ago before i went 4". they are a bit more exxy, but a far better kit compared to the thai made ones.
if you go with a drop cradle kit, you should be able to clear 35"s with a small amount of trimming on the plastic flaring in front and behind the tyres.
