What Brand Tyres and Size do you use?
  • #61
    Re: What Brand Tyres and Size do you use?
    I had my bridgies rotated balanced etc today and was asking about tyres and suggested LT, the boys tried to tell me that i would have problems balancing a LT tyre on a prado, they reckon they are too heavy and don't balance up good, i told them a lot of guys are running LT on the forum. Any comments on the LT balancing up. They did cooment that they have had some good reviews about the GO12 yoko AT.
    [b]Rob[/b]
    • #62
      i have the mighty stt's which have now done over 35000km's..AND THERE IS STILL HEAPS OF TREAD ON THEM...!!!
      I keep mine on full time and rotatae without fail every 5000km's..
      i dont bother with a second set as i work away 2 weeks on and 2 off , so when i am home mine are off the road half the time ,
      any way i think they handle the black stuff well especially after just finishing a 7000km round trip from Cairns to Newcastle....
      when they wear i will just get another set
      joey
      -issue 52 Modified 4wds .
      • #63
        So as far as AT tyres go, my short list is this Grandtrek AT3's, BFG AT's, Yoko G012's and Wr/Silent Armor. :? :?
        Can I get a show of hands and any considered opinion to assist with my upcoming purchase?
        Currently running Cooper AT''s 265/65R17 that have done 70+ thow and have had no probs off road. However I find them a little slippery in the wet on the black stuff and tend to track quite a lot.
        As 80% of my driving is done on road, probably more if I'm honest, I'm keen to try something with silicon in it and in a 70 series.
        Any thoughts on the above tyres much appreciated.
        • #64
          Apor have you actually read through the tyres threads all the info and more is already covered about all of those brands.
          [b]Rob[/b]
          • #65
            Yah sure, but I'm looking some current thinking from the good people reading this thred... but thanks for your thoughts HUTCH.
            • #66
              Only a couple have AT3 and the silent armor, their is a thread on the BFG and Yoko's that is current as of this week.
              [b]Rob[/b]
              • #67
                BFG A/T
                265 x 70 x R17
                Reputation and longetivety pushed my hand deeper into my pocket.
                No regrets.
                Highest bungee jump in the world.
                [url="http://www.youtube.com/watch?v=OxxTDQzRrkU"]http://www.youtube.com/watch?v=OxxTDQzRrkU[/url]
                • #68
                  just put a set of Cooper ST 10ply LTs on 245/70/17s on 7.5'' alloys
                  Keeps it all legal on flareless GX.
                  04 GX V6,Billstein/Ridepro 2''lift,Polyairs,7.5''alloys,Cooper STs,GME 3220 UHF,MIO GPS,TJM portable compresser,
                  Sovereign alloy bullbar,Toyota towbar/steps.
                  • #69
                    noticed a lot are running 265/70/R17 instead of the standard 265/65/R17
                    anyone know where i can find what the rules are in QLD on changing tyre size? I 've seen different stories bantered around in a number of threads but 't don't recall seeing a link or direct quote from Qld Trans or similar
                    found this link that helps work out the specifics. http://www.miata.net/garage/tirecalc.html
                    circumference difference of 3.3 inches is about 3.43% bigger, which is less than 5% (if thats the magic number) or is it the 65 to 70 thats the prob? i.e 5/60 is 8.3% which is more than 5%?
                    im confused!
                    • #70
                      aahh, I think I've sussed it . QLD allows 15mm diameter change.. 265/65= 776.3mm 265/70= 802.8mm = 26.5 mm bigger...
                      bugger.
                      • #71
                        Straight out of Qld Mod booklet
                        Width
                        an off-road passenger vehicle fitted with
                        front and rear beam axles, the maximum tyre width
                        must not be more than 1.5 times the vehicle
                        manufacturer’s widest optional tyre.
                        The nominal width of the narrowest tyre fitted to a
                        vehicle must not be less than 70 per cent of the nominal
                        width of the largest tyre fitted and never less than the
                        vehicle manufacturer’s narrowest optional tyre as
                        indicated on the manufacturer’s tyre placard.
                        Track
                        Track is measured at ground level from the centre of the
                        tyre on one side to the centre of the corresponding tyre
                        on the opposite side of the vehicle. Front and rear track
                        differs on many vehicles.
                        The wheel track must not be reduced to less than the
                        standard track specified by the vehicle manufacturer
                        for the particular model of vehicle.
                        Off-road passenger vehicles fitted with front
                        and rear beam axles, may have an increase in track
                        up to 50mm beyond the maximum specified by
                        the vehicle manufacturer for the particular model
                        of vehicle.
                        Diameters
                        The rim diameter may be varied from the standard size
                        but the overall diameter of the tyre must not vary by
                        more than +15mm or -26mm.
                        Black 2008 D4D GX, Bolle tint, Airtec snorkel, Hayman Reese tow bar, Staun deflators, ARB Air, front & rear extended diff breathers, Milford cargo barrier, Poly Air, 2" lift, XGS suspension, road tyres - 265/65x17 Grandtreks, play tyres - 265/70x17 Wrangler MTR's, ARB Sahara Bar, TMax 9000 winch, custom winch panel, Uniden UHF, Garmin 76csx with RAM mount, Eee PC with OZI, triple IPF 900XS spotties, rear ARB diff locker, Brown Davis underbody protection, Darren McRAE Auto Craft Rock Sliders
                        • #72
                          thanks James, out of curiosity being a qlder running 265/70s have you done anything re Insurance or compliance?
                          I saw an earlier post on 245/70's which have almost exact same diameter as 265/65 anyone gone down that path?
                          • #73
                            Anyone got any info on Vic regs?? :?
                            • #74
                              In short - No.
                              My 70's are only put on for a play time trip and aren't my everyday tyres which are 65's, however this thread has made me have a good think, particularly about insurance complications.
                              Come monday, i'm going to ring up an AIS (Approved Inspection Station) and see about getting an inspection and mod plate fitted.
                              • #75
                                In short - No.
                                let us know how you go! i wouldn't even know the first place to look for a number to find someone that does the mod/compliance plates!
