TYRE MUSTER
  • Re: TYRE MUSTER
    My experience with ST's was pretty lousy
    Took a 70 series set 5000 klm old out to the Flinders for two weeks and absolutely tore them to pieces, lugs missing, miles of chipping and all 4 damaged beyond reasonable
    Contacted Coopers who swapped them out for a set of STCs which are now over 30000 klm old and have been excellent, very minimal wear and still looking in tip top shape
    Noise wise they are a bit ordinary, maybe a touch quieter than ST's
    My guess is that they will do 60000 klm easy
    • Re: TYRE MUSTER
      if there is a place where cut resistant tires are needed it;s the northern Flinders/Gammon Ranges!
      How much are the ST's and ST-C's?
      Sig035......they look fantastic BTW :mrgreen:
      _______________________________________
      [SIZE=1][B]2011 Silver 150 DVD[/B] [B]GXL[/B][/SIZE][SIZE=1], Safari Snorkel, Sand Grabba mats, Michelle Sacs seat organizer, ARB Bull Bar, Lightforce 170 HID, Bonnet and Headlight protectors, Dual Batteries, Engel Fridge, Kaymar rear spacer, Cooper STTs [B]x 6[/B], Rhino Pioneer tray in black, MaxTrax, Black Widow Drawers with top shelf, divider & cargo barrier, ARB Sports Nitrochargers and springs, ICOM IC 440N CB
      [/SIZE]
      • Re: TYRE MUSTER
        Paid $365 each, which was about the norm.... and they threw in a wheel allignment.
        Ment to mention..... picked up another 2.5cm height as well...... which means I can only get the Prado in the garage now if I have more than half full tanks :mrgreen:
        [color=#0040FF]Rob[/color]
        • Re: TYRE MUSTER
          Maybe you picked up 12mm or 13mm in overall vehicle height ?
          265/65/17 = 769.5mm
          265/70/17 = 796 mm
          • Re: TYRE MUSTER
            265/65/17 = 769.5mm
            265/70/17 = 796 mm
            ....Yep agreed.....Plus the 60,000klm wear on the ATR's.....about another 10mm
            • Re: TYRE MUSTER
              Geez...running a bit tight there :shock:
              Not a bad price with a wheel alignment. They do look the goods but you have only corrupted my indecisive decision making for some footprints :!: :!: I am interested in the ST-C's for their cut resistance but could but the STT's or MTZ's. Could have less road noise with these.....oh geez :!: What to do :?
              [/SIZE]
              • Vehicle: 2003 Toyota Prado 120 Grande
                Tyres: Yokohama Geolander ATS GO12 265/65/R17
                Terrain: Bitumen so far...intended for Fraser Island
                K's 1000! Just upgraded from the Grand Craps (I hope!!!!!)
                Impression: So far So good. Stable, good tracking straight/corners, reasonably quiet although very slightly noisier than grand craps, good on loose gravel, eagerly waiting to try sand!
                Good Points: Sexy tread pattern, good LT side wall construction, plenty of tread for an AT
                Thoughts of replacements: hopefully not for a long time yet!!
                [COLOR="#000000"]2003 Grande, Maxtrax,ARB rear and side awning, Rhino rack, GME 3100 UHF, Sony 2DIN DVD/reverse camera, 2x 9" headrest DVD's + 2x 7" headrest DVD's, Aries sheepsking custom covers, 2" raised kings, ARB underbonnet high output compressor, Hybrid dual battery with fuse box and additional outlets in rear, Rear door table, High power reverse LED flood, Staun deflators, ARB snatch hitch and strap, PP sticker[/COLOR]!
                • I'm with Brad. Bought my Geolanders only two weeks ago, so i don't have any playtime with them under my belt yet :P I know some people who have them and they are very happy with the performance. The word of mouth, the price and the warranty are all good points as well
                  • Vehicle: 2009 120 V6 Prado on alloy rims
                    Tyres:
                    Current : BFG AT's 265/65/17
                    Previous : Dunlop Grandtrek AT20 265/65R17 (std)
                    Kilometres :
                    Current : 3,500
                    Previous : 80,000 +
                    Impressions: I've never got less than 80,000k out of the Grantreks and found them to be exeptional for on-road use and light off-road use. The reverse applies to the BFG AT's. Good off-road with less perforance on-road ( as expected )
                    Bazza.
                    • Michelin Latitude Cross
                      Anyone know anything about these??
                      • Vehicle: 2003 Prado 120 running 90 series 16" GXL rims.
                        Tyres: Kelly TSR 265/75/16
                        Previous: BFG A/T's on 120 series GXL Alloys 265/70/17
                        Terrain: 70% Road
                        Km's: 53,000 so far
                        Current Tread: 12mm
                        Pressure: 40psi-Front, 42psi-Rear.
                        Impressions: When brand new in the wet well lets just say thanks for All Wheel Drive, After id scrubbed them up a bit much much better. Great traction tyre in mud and stable with low pressures. I do lower them every chance i get to go with terrain, no chipping, no cracks, no lost or cut lugs, no punctures either. They get rotated every service and still look in great condition, look good on the rim too.
                        Next Set: Will stick with them!!!!
                        Trav.
                        • kelly tyres
                          I had the same tyres on my Prado ,good solid tyres no punctures lasted years . I had the pressures at 35/36 though . must be hard as with 40+ in them.
                          QUOTE=travis.luke;457899]Vehicle: 2003 Prado 120 running 90 series 16" GXL rims.
                          Terrain: 70% Road
                          Km's: 53,000 so far
                          Current Tread: 12mm
                          Trav.[/QUOTE]
                          • Hi Raydes,
                            Unloaded in the rear i do feel it but the rears set up stiff to tow with and its always got a bit of weight in the rear- Fridge, Tools, Etc.
                            Front seems good though.
                            I must have to admit with a lot of the guys i get out with following the BF, Copper and Micky band wagon i have nothing to complain about with these tyres, i don't expect to get high kms out of them and at the end of the day its a big car that tows and being used as it should be.
                            Good solid tyre and im happy.
                            Thanks, Trav.
                            • i have a 2004 grande 4.0L V6 with standard rolling size cooper ATR's i have no idea how many ams are on them as they were on it when i bought the car but i am in need of a new set of rubber so this is good to see so i no what i can expect, i don't go too far off road, just a dirt track to get to fishing spots and thats about it.
                              • Just changed over from Pirelli Scorpion ATR's which were great on the road, in the sand and off road, except for in the mud! So now we have D697's which are more aggressive but not as aggressive as BFG's which my wife vetoed.
                                Tyres: Bridgestone D697's 265/65/R17
                                Previous: Pirelli Scorpion 265/65/R17
                                Terrain: 95% Road which will change after the GTG!
                                Km's: 1,000 so far
                                Current Tread: NEW
                                Pressure: 40psi
                                Cheers, Brad
                                2007 GXL, Dune, D4D 6 speed manual. Satnav, towbar, Sahara Bullbar, Bridgestone D697's, Cargo Barrier, Stebel Truck Horn, Couplertec Rust Protection, Safari Snorkel, Polyair airbags, Blue Narva 175's, VMS Touring 700HDsII, GME TX3340, Tough Dog 2" lift with adjustable shocks, ARB rear air locker.
