I run with Turbo Boost, Water Temp, LPH and KMH (set for my tyres) The X Guage for the turbo boost is very good, keep half an eye on it when going uphill towing and modulate the right foot to keep the boost just under the kickdown point. Talking about guage accuracy, Has anyone noticed strange results from fuel use when 4wding. You can drive on sand in low third and get 12LPH. Then require 20 litres less than the guage says when refueling. Running on the black stuff towing or not it is always within a litre. The instant fuel use readout does not seem to take gearing into acount. Manually drop down a gear going up hill and the fuel use drops 20 percent or so!!!
Scangauge II 150 series codes - trans temp and others
Yes, mine runs fine on this setup.Originally posted by D4D View PostHas anbody got the ScanGauge to work with a 120 D4D 5 speed auto?
Robert[B]Robert
They seem to pretty accurate to me. Updates every second or so.Originally posted by D4D View PostThanks Robert, how accurate are the numbers?
I got the bios upgraded from version 3 bios to version 4 so it could read the Auto temp as well. (Version 3 wont).
I run Water temp, ATF Temp, Volts and Revs readings on mine.
You can also clear ECU codes etc.
Of course it always good to see what the trip litres per hundred is on the diesel as well , so I can rub salt into the wounds of my petrol commrades ;-)
Robert[B]Robert
RoughlyOriginally posted by D4D View PostThanks again Robert. What temps are you seeing?
-Water temps arpound 87-90 degrees
-ATF about mid 80ish normally. But have seen up to 100ish on some 4wding. I dont tow anything. This is a lot more variable then the water temp as you can imagine, you can see the temps rise sitting in drive in heavy traffic/ lights and fall as you move. etc.
Robert[B]Robert
Stock 150 and have been running the Unit for 2 weeks now.
water temp - in any condition has been from 82-86c
Auto - sits around 75, but seen it peak at 89c
Dose anyone have the codes for Air/Fuel ratio?Prado MY14 150 Series Altitude - Rhino Pioneer rack with backbone system, Tint, Fuel Manager Pre-Filter Fuel/Water Separator, Mann Provent 200 oil catch can, Toyota 2.5T Tow Bar, Scangauge2, TJM T3 winch bar, Narva HID 225, Polyair Air bags, 2" lift (Bilstein & Kings), Uniden 7700 with GME AE4018BK3, 32" LED Light bar, 2mt Awning, 1100mm Treds with mount plates
Originally posted by evltoy View PostStock 150 and have been running the Unit for 2 weeks now.
Did you use the code Davad73 posted?
What year model is your Prado?
Just ordered a scanguage and curious to see what works on my 2013 Prado
I believe those are the codes I used.
my truck is a 2014 AltitudePrado MY14 150 Series Altitude - Rhino Pioneer rack with backbone system, Tint, Fuel Manager Pre-Filter Fuel/Water Separator, Mann Provent 200 oil catch can, Toyota 2.5T Tow Bar, Scangauge2, TJM T3 winch bar, Narva HID 225, Polyair Air bags, 2" lift (Bilstein & Kings), Uniden 7700 with GME AE4018BK3, 32" LED Light bar, 2mt Awning, 1100mm Treds with mount plates
Just got my Scangauge ! Im pretty impressed with it!
For some reason i keep on getting a continuous loop of pending trouble codes. It keeps on counting up to 99, then starts again. Does anyone know of a fix for this?Last edited by Nightrod111; 08-05-2015, 04:58 AM.
Thanks for bring this up nightrod111.
When I thought I had a boost reading issues I run the test to see if I had any pending code errors. I can tell you that I get the same as what you describe.
Doing a scan will just do a scan and repeat I believe - someone correct me if wrong. If you have no errors recorded after pressing the scan button from the main menu I think you are ok.Prado MY14 150 Series Altitude - Rhino Pioneer rack with backbone system, Tint, Fuel Manager Pre-Filter Fuel/Water Separator, Mann Provent 200 oil catch can, Toyota 2.5T Tow Bar, Scangauge2, TJM T3 winch bar, Narva HID 225, Polyair Air bags, 2" lift (Bilstein & Kings), Uniden 7700 with GME AE4018BK3, 32" LED Light bar, 2mt Awning, 1100mm Treds with mount plates
