Scangauge II 150 series codes - trans temp and others
    I run with Turbo Boost, Water Temp, LPH and KMH (set for my tyres) The X Guage for the turbo boost is very good, keep half an eye on it when going uphill towing and modulate the right foot to keep the boost just under the kickdown point. Talking about guage accuracy, Has anyone noticed strange results from fuel use when 4wding. You can drive on sand in low third and get 12LPH. Then require 20 litres less than the guage says when refueling. Running on the black stuff towing or not it is always within a litre. The instant fuel use readout does not seem to take gearing into acount. Manually drop down a gear going up hill and the fuel use drops 20 percent or so!!!
    Prado Polar White 150 GX 3.0 TD Auto. HR TB, ARB delux bar, Hella R2000 lights, Magnum winch, ARB 50mm lift, BFG AT 265/70R17 on 71/2" alloys, Alloy side steps, Rhino sport bars, Tint, UHF, Scangauge, Aux batt (ABR kit), Cargo barrier, 50l water tank, Storage system, Elec brake con. ARB compressor
      Has anbody got the ScanGauge to work with a 120 D4D 5 speed auto?
        Yes, mine runs fine on this setup.
        Robert
        [B]Robert
          Thanks Robert, how accurate are the numbers?
            They seem to pretty accurate to me. Updates every second or so.
            I got the bios upgraded from version 3 bios to version 4 so it could read the Auto temp as well. (Version 3 wont).
            I run Water temp, ATF Temp, Volts and Revs readings on mine.
            You can also clear ECU codes etc.
            Of course it always good to see what the trip litres per hundred is on the diesel as well , so I can rub salt into the wounds of my petrol commrades ;-)
            Robert
            [B]Robert
              Thanks again Robert. What temps are you seeing?
                Roughly
                -Water temps arpound 87-90 degrees
                -ATF about mid 80ish normally. But have seen up to 100ish on some 4wding. I dont tow anything. This is a lot more variable then the water temp as you can imagine, you can see the temps rise sitting in drive in heavy traffic/ lights and fall as you move. etc.
                Robert
                [B]Robert
                  Changed my display today to include ATF . I have entered the code, but a little confused on the readings. At cold I get 3.2 (or thereabouts), and once warm it climbs to around 7.0. What is this?
                  [color=#0040FF]Rob[/color]
                    Hi Signature035, Try this code below for Trans temp. Will work from 2011 Prado onwards that I know of;
                    +07E121D9 (TXD)
                    +032180000000 (RXF)
                    +1810 (RXD)
                    +0003004DFE70 (MTH)
                    (3 letters available so name it as you wish)
                    Just check the code you have with the one above.
                      Stock 150 and have been running the Unit for 2 weeks now.
                      water temp - in any condition has been from 82-86c
                      Auto - sits around 75, but seen it peak at 89c
                      Dose anyone have the codes for Air/Fuel ratio?
                      Prado MY14 150 Series Altitude - Rhino Pioneer rack with backbone system, Tint, Fuel Manager Pre-Filter Fuel/Water Separator, Mann Provent 200 oil catch can, Toyota 2.5T Tow Bar, Scangauge2, TJM T3 winch bar, Narva HID 225, Polyair Air bags, 2" lift (Bilstein & Kings), Uniden 7700 with GME AE4018BK3, 32" LED Light bar, 2mt Awning, 1100mm Treds with mount plates
                        Did you use the code Davad73 posted?
                        What year model is your Prado?
                        Just ordered a scanguage and curious to see what works on my 2013 Prado
                          I believe those are the codes I used.
                          my truck is a 2014 Altitude
                          • #28
                            Just got my Scangauge ! Im pretty impressed with it!
                            For some reason i keep on getting a continuous loop of pending trouble codes. It keeps on counting up to 99, then starts again. Does anyone know of a fix for this?
                            Nightrod111
                            • #29
                              Ordered my Scanguage II from Ample but they are out of stock so it is back ordered....
                              Still undecided where to position it in the prado...
                              • #30
                                Thanks for bring this up nightrod111.
                                When I thought I had a boost reading issues I run the test to see if I had any pending code errors. I can tell you that I get the same as what you describe.
                                Doing a scan will just do a scan and repeat I believe - someone correct me if wrong. If you have no errors recorded after pressing the scan button from the main menu I think you are ok.
