Bummer OK
RJ45 pass through for UHF radio
Okay... so I bought the connector from AMTS (quality product visually), I’m now ready to install the thing. A question - being a nerd, I understand how twisted pair cabling works. However, what I don’t understand is the pin layout for the cable required. Can I simply just get a network cable and plug it into my icon440 and the other end into AMTS’ socket for the hand piece to then connect to? I probably haven’t explained this very well... here’s hoping.
update: simply I just grabbed a standard computer Ethernet cable and it worked. I think I tried to make it more complicated. Great plug AMTS - thanksLast edited by dizy-150; 30-04-2019, 08:25 AM.
Yes, you would need an RJ45 splitter but don't think you can use both mics at the same time. 1 mic in either location would work. Here is an example.Originally posted by Robere View PostCan you have 2 points connected in parallel so the mike can be used in 2 different locations?
https://rover.ebay.com/rover/0/0/0?m...2F173788353437Last edited by amts; 22-06-2019, 07:48 AM.
I thought I'd post a reply to this , pretty late I know. The STEDI page has a very good range of in-dash plug-ins. Take a look at
https://www.stedi.com.au/short-type-...es-toyota.html
