150 Cracked Inner Guard List
This is a sticky topic.
  • Originally posted by rob_macca67 View Post
    Has anyone who has had a inner guard crack also had bracing of their battery to the front panel to help prevent forward/backward movement?
    rob
    I have had both of mine crack, I have had mine welded and made apron braces for both batteries, no signs of cracks yet, I still have the patch in the workshop that I have not put in yet. I would agree bracing the top of the battery would prevent it, if you get a car with a cracked guard just put your hand on top and rock the battery and watch the crack move. bit of a shame that this was not a factory revision.
    • My aux battery was braced when fitted pre delivery. 150k so far no cracks so far, which I am very pleased about.
      • Originally posted by REV View Post
        Is your starter battery braced also? Mine cracked on the passenger side which is where the starter (original) battery is, not the drivers side where the aux battery is.
        • Time to add mine to the list#
          Member: SAPRADO
          DOM: 12/2011
          Engine: D4D
          Model: GXL
          Crack Location: Passenger Side#
          Crack appeared @: 117000
          Toyota Response: I don't need or want the argument with these clowns.#
          Outcome: purchased the patch kit and will weld the crack and fit patches myself.#
          Battery & Weight: Original toyota battery
          Battery Tray: OEM tray still
          Tray Modifications: will make /buy steel tray similar to TJM tray on drivers side.#
          Vehicle Modifications: TJM bullbar, winch, Bilstein/Dobinsons 50mm suspension, ARB compressor under bonnet and Redback AGM battery on drivers side on TJM tray. Rear drawers, Under guards.#
          4WD Trips: Fraser Island, Simpson Desert, Beachport/Robe/Carpenters Rocks some local touring nothing extreme just family touring.#
          • Double post sorry.
            • No, Starter battery not braced.
              • Bracing doesn't actually transfer the load, all it does is possibly stop some minor movement. End result is same stress on the stress point. I discussed this in detail somewhere when I first raised the cracked guard issue on the 150.
                From my research when it first happened the cracking appears to be caused by vibration such as from corrugated roads. There may be some benefit in placing the battery on some heavy vibration suppression foam, as it smooths out the vibration load on the guard. I did this and it hasn't done any harm.
                Incidentally my guards with patch kit and weld have stood up to 3 more years with no further issues. Hopefully not jinxing myself!
                [B]Steve[/B]
                • Hi guys
                  Can someone who has puchased or fitted the patch kit for the 150 Prado from Toyota please confirm for me that it contains only one sheet metal patch per side.
                  On a side note the bolts and nuts are still available. Just purchased the kit $358.65 in total , nuts, bolts, plastic inner guard clips and two metal patches.
                  Regards SAPRADO
                  • The earlier 150 don't have the revised inner fender design so yours may well be like my 120 where I installed four plates.
                    • Originally posted by saprado View Post
                      Hi guys
                      Regards SAPRADO
                      My 150 repair only has 1 metal patch per side mounted under the inner guard.
                      4WDriver since 1975, current 4WD, 2009 GX diesel auto 150 series, fitted with ARB bullbar, snokel, dual batteries, rear draws, water tank, mud tyres, side steps, 50mm lift & roof bars. Tow a Olympic Champion XPack caravan, travelled a lot of Australia, past big trips in 150, August 2010 - Hay River Track NT, July 2011 - Kimberleys and WA, July 2013 - Canning Stock Route WA.
                      • Thought I should update what is going on.
                        Managed to get it in to the Toyota dealer and the service guy took some photos and then disappeared out the back for a bit. Comes back and said he needed some more photos. Whilst walking out to the car he mentioned it was common problem with the auxiliary battery, I told him thats awesome but this is on the OEM battery side, not the aux side. He took some more photos then disappeared again.
                        Next he returns with the service manager for a look. Same as above, who installed your aux battery, its a common problem. I said, yep I would agree with you but this is on the other side of the car, nothing to do with the aux battery... The service manager seemed to think due to it being on the passenger side it should be covered.
                        Next day dealer rings, you will need a quote from a panel beater before they can submit the claim to Toyota (which I find absurd, either you will cover it under warranty or you won't. I don't understand how a quote changes this). Anyway I got the quote to get it fixed, so now just waiting for an official response from Toyota.
                        Member: Bailey84
                        DOM: 12/2012
                        Engine: D4D
                        Model: GXL
                        Crack appeared @: 65,000km
                        Toyota Response: Took it for an inspection yesterday, initially told me I had to book it in to be inspected and if it wasn't covered by warranty it would be a minimum $150 fee. After some stern words, they agreed to have a look and take photos, just not today (yesterday) because they have a new computer system and can't spare the 5 minutes.
                        Outcome: Not there yet but from the dealers reluctance to even look at the car it doesn't look good.
                        Tray Modifications: None
                        Vehicle Modifications: ARB bullbar, winch, Ironman suspension, ARB compressor under bonnet and ARB battery tray and Century N70ZZ battery on drivers side.
                        4WD Trips: Cape York and Fraser Island a couple of times, some local touring nothing extreme just family touring. The car sees mostly dirt road driving due to where we live.
                        • Originally posted by Bailey84 View Post
                          Well heard from the Toyota Dealer today, they have advised Toyota have declined the warranty claim as it is not a manufacturing fault and it was caused by the aftermarket suspension.
                          The dealer has told me to ring Toyota directly if I want any more information.
                          So I guess tomorrow its a phone call to Toyota for their official response.
                          • That's their standard response. Even if you show them examples of Prado's with stock suspension and cracks they will not admit they have a problem with their product. The fact that they make a repair kit and that they changed the inner guard design in 2014 clearly shows to me they know they have a problem.
                            I got them to at least supply the parts kit.
                            • Is this just an issue with the older 150 models, or brand new ones also?
                              • All pre the update in 2014. New ones have a different inner guard setup
