Useful Wire Colors and locations
  • #91
    I am looking for an ingnition source in a Prado 150GXL Diesel. I tried the pink wire behincd the mirrow switch but this is on with acessories.
    Any other thoughts where I can get and ignition source under the dash in the cabin.
    Mike
    • #92
      Mike
      Post#78 and before on this thread is worth a read.
      Geoff
      • #93
        ING wire under Dash
        Read post #78 and the tap off is in the engine bay. There are haps of sources in this location.
        I ran out of time and took to an auto sparky. After spending some time reading the wiring diagram he connected it to the accessories. After pointing out I wanted the ignition source he fixed it in a jiffy. Total cost $20.
        • #94
          Originally posted by Prone View Post
          Further to my post #35 on this topic of Easy 12Volts access at rear of car.
          It is possible to buy terminals with short leads on them from Mr Toyota (for a largish sum unfortunately, but less than $10 I think). This then enables you to insert the "repair wire" into the trailer socket and get easy connection to the unused wires that have 12V at R23.
          The part numbers are -
          Repair wire 4.8mm 160mm 82998-12370
          Repair wire 2.3II 160mm 82998-12330
          These will fit into the trailer side plug that fits into the trailer wiring socket R23.
          They will allow easy connection to the two grey wires in the towing harness Socket R23.
          The grey wire with the smaller 2.3mm connector is only at 12V when the ign is on, but not at the accessory position. It is protected by a 7.5A fuse and this circuit is used by quite a few other important circuits. Probably best not to try to draw much power from this circuit. I will use it to switch a relay connected to the larger diameter grey wire.
          The grey wire with the larger 4.8mm connector is permanently at 12V and is protected by its own 30A fuse "Towing Brake".
          Prone
          I have been looking for this connector for days now. I finally found the right part number from the manufacturer (yazaki) and have to order a min quantity. Came back to this thread for something else and found this post - what a relief.
          What is the difference between the two parts and do they suit both the 120 & 150?
          Would still prefer an unterminated connector for the harness I want to build.
          There are plenty of connectors that I am after. I want a male and female connector of the one under the dash where the acc power is. I can then make a small Y harness that would allow me to tap off the power without damaging the original harness.
          Mick
          • #95
            Anyone know which is the correct wire for tapping 12v IGN on power for a rear DVD system, I am thinking the 12v socket under the rear a/c controls - need about 3A draw, going to use a wire tap but not sure what colour wire is the 12v +
            2014 GXL
            [/CENTER]
            • #96
              Symo. From memory it'll be grey. But the negative is white/black.
              • #97
                cheers
                [/CENTER]
                • #98
                  does anyone know where the A/V input is for the 2014 facelift (VX) model .... ("A/V" when choosing an audio source)
                  • #99
                    Can someone tell me if there is a plug in the loom of a 150 for the trailer plug?
                    if so maybe supply a photo?
                    My trailer light having been giving me grief and looking into it I have found some really ordinary wiring supplying the plug, it feeds offthe back of the left hand tail light with one wiire picking up the right hand indicator.
                    I figure Toyota would have a better point in the loom to connect the trailer plug.
                    I just want to tidy the whole thing up.
                    • There is a plug that the factory loom fits into.
                      http://www.toyota-tech.eu/Aim/Aim.aspx
                      Go to the site, select LC150 and build year 2013 on and then Installation Manuals and Towing Hitch Wiring Kit. Shows you everything you need to know.
                      mjrandom
                      Out of control poster!
                      Last edited by mjrandom; 07-01-2016, 02:36 PM. Reason: Took a while to get the links...
                      • Originally posted by Oscartangotango View Post
                        There should be more than just a plug... ours (2015 GXL) has a trailer "interface" box (can't think of the right word) so that the trailer doesn't go in parallel with the vehicle lights. It shows up on page 24 of the instructions here.
                        If they have wired directly to the tail light it doesn't sound like it has been done "properly".
                        peter_mcc
                        • Hi, just starting to fit all the bits back in the 'new' 150. Dual battery is done, now looking at the brake controller.
                          Car has a genuine tow bar and wiring loom. Blue brake wire has a corresponding black/red wire at the plug in the Jack hides hole.
                          Anyone know where this goes? MY 2010
                          Cheer, Greg
                          • Thanks for the information fellas. This really helps with some ideas on where to get power from etc.
                              Bad ground I bet.
                              • Originally posted by bj0075 View Post
                                Guys I have an altitude, and the most annoying thing I have found so far is the fact I can't change / scroll through my songs on USB while driving, it greys the button out while moving!!!
                                Does any one know which wire where I need to ground to get around this
                                BJ
                                Not sure if you found this or not. But post #100 show a link to some Toyota site. I had a look around if if you select LC150 then 2013 onwards then installation then audio you get 3 selections on the right side to pick from I looked at the file with RHD on it. and I think it shows where you the speed sensor for the screen and how it connects to the dash thus if we can get it removed you might be able to make selections without having to stop or go stupid slow I believe there is also the handbrake sensor on the same cable.
