XGauge commands/codes 150 Prado
    Originally posted by Mild7 View Post
    Hi guys, I just wanted to get all of my codes for the 1GD , from various threads all in one place. Can anyone confirm that these are all correct?
    Also, what does "Custom command to start burn" mean? Can I force a burn using the SGII? When would I want to do that?
    AUTO TRANS FLUID TEMP (ATF):
    TXD 07E02182
    RXF 046105820000
    RXD 2808
    MTH 00010001FFD8
    TORQUE CONVERTER TEMP (TCT):
    TXD 07E02182
    RXF 046105820000
    RXD 3808
    MTH 00010001FFD8
    EXHAUST GAS TEMP (EGT):
    TXD 07DFO178
    RXF 054106780000
    RXD 3810
    MTH 0001000AFFD8
    DPF TEMP (DPF):
    TXD 07DF0178
    RXF 032100000000
    RXD 2010
    MTH 0001000AFFD8
    DPF % ACCUMULATION LEVEL (DPA):
    TXD: 07E02138
    RXF: 032104780000
    RXD: 4008
    MTH: 000200010000 ( x2 % ) or
    000100010000 ( x 1 % )
    Custom command to start burn: 3029060101
    Mike.
    HI, thanks for sorting these codes, and could you tell me: MTH: 000200010000 ( x2 % ) or 000100010000 ( x 1 % ), in the part of DPA, what is the difference between these two? Cheers!
      x2 will give you a value of double the x1 value. so for example if your DPF is at 30% ( 0 to 100% ) on x1 it will show 60% full on x2. ( 0 to 200 )
        Sorry, I missed that question
        joejoejoejoe
        joejoejoejoe Nudgebar has you covered..
        So I tried the DPF temp code again and again. It only gives me a decimal reading.. For example 35.5. Does that mean 355 degrees? Or have I got the wrong code? Im pretty good with this sort of thing, but can work this one out. I just posted a question in the fual ecconomy thread about DPF burns. Maybe I have an issue with my filter.
        2015 2.8L GX Auto. White. TJM Outback Bar and side steps, IPF 900s, Runva 11XP Winch, Safari Snorkel, Dobinson/Bilsteins, BFG KO2, Uniden UH7700nb with RFI CD34 antenna, Marine Pro 620 Dual Batt with SBI12, Waeco CFX50, Scangauge II, WindCheetah Slimline II Rack...
          joejoejoejoe
          No worries mate! My scan gauge is on the way. And I will let you know after I installed it if we have the same reading. Cheers!
            It should match closely to the EGT code as it is just after the turbo.
            I would be expecting to see it around 100-350 when driving and around 400-650 degree when regen in progress.
            I normally see 3 digits, not a decimal place... I would recheck the codes you have typed in.
            The above codes work for me which I have placed into my SG in a 2018 vehicle.
              joejoejoejoe
              I just got mine. It looks fine. Just a reference for you.
                Joe - Looks like its just about to finish a burn!
                Scary how hot they get...
                  But smells good (^▽^)
                    Is there a toyota specific MAP code? My reading on the scangauge is different compared to techstream. I've got a tune and on scangauge i get 170ish and on techstream i get to 220.
                      An update about the gauge, my regen starts from DPA 50, ends at DPA 3, which means if you use the code 000200010000 ( x2 % ) instead of
                      000100010000 ( x 1 % ). It may show you DPA 100 before regen. Because it may be showing different readings in different vehicles. Have a nice day guys!
                        Originally posted by nudgebar View Post
                        Automatic Transmission Fluid ( ATF )
                        TXD 07E02182
                        RXF 046105820000
                        RXD 2808
                        MTH 00010001FFD8
                        Torque Convertor Temp ( TCT )
                        TXD 07E02182
                        RXF 046105820000
                        RXD 3808
                        MTH 00010001FFD8
                        Nudgebar
                        can you give me the codes for a 2007 vx 1kd 120 diesel? I have tried all the apparently relevant codes in the list from the scan gauge website without success.
                        ian
                          sorry i cant help you with that , I got those codes from a Tacoma website some time back.
                          • #28
                            The EGT code is driving me nuts...... I am using a Ultragauge and cannot get EGT temp working. I have a 2018 GXL. The last byte of the TXD is 78. When I do a scan of what the car supports, 78 does not appear...... Does anyone have EGT working on a scangauge on MY18 update?
                            • #29
                              I've given up on Ultragauge, Scangauge has more support.
                              For EGT1 the codes specified above work for me on my 2018 GXL:
                              TXD 07DF0178
                              RXF 054106780000
                              RXD 3810
                              MTH 0001000AFFD8
                              • #30
                                thanks RPP....got me completely baffled why 78 doesnt appear yet it woirks. thanks for the confirmation.
