So drumrolll..... got it working. Thanks for the input and ideas guys. WIll post the answer in m gauge thread.
XGauge commands/codes 150 Prado
What is a diffrence between DPA gauge as quoted and DPF Soot Load (%) - STL which is published on SG web site?Originally posted by nudgebar View PostDPF Level Accumulation Guage ( DPA ) ( in % )
TXD: 07E02138
RXF: 032104780000
RXD: 4008
MTH: 000200010000 ( x2 % ) or 000100010000 ( x 1 % )
custom command to start burn is - 3029060101
DPF Soot Load (%) -STL 07E02138 032100000000 4008 000200010000
Hi All,
Scangauge doco has "DPF Regen State (states) RGN(1)" and "Exhaust Fuel Addition Injector Status (EFA)" X-gauges under their "Toyota 2016+" list.
Neither work for me (2017 model 1GD) but would be nice to have access to these or similar to get a fuller DPF picture. Does anyone have further info on these or similar working codes ?
PS:
"DPF TEMP (DPF):" and "DPF % ACCUMULATION LEVEL (DPA):" per post #12 (p1) both work fine for me.
A 2014 Prado would have a 5-speed gearbox, so I can't help you much (mine is the 6-speed). Apart from: keep searching - there are several threads on gearbox PIDs here. And, I think the older US Tacoma used the same 5-sp gearbox, so you may find info there if you don't find it on Pradopoint.
- 1 like
