have too wait for Monday, public holiday here today in Darwin for the Darwin show, post office is closed.
Steve any chance you could post a couple of pics of your Dash cam installed as SteveM has deleted his pics.
Bill
I copied SteveM's install (mostly) Let me know if you want some photos, not sure if yours is the same. Mine's a 120.? Run cable along roof lining, down behind drivers pillar trim (two bolts to remove it), pass cable through gap into footwell (unlike SteveM I didn't remove the footwell trim, I found if I doubled the cable over I could thread it through the gap and then pulled the cig adaptor through. ) I ran it behind the trim to the power outlet, and just cable tied the excess and hid it behind the drivers kick panel.
At some point I'll run it to the aux battery for permanent power so I've left the final section exposed - Steve ran his behind the trim.
r4ndll,
if you could post those pics of the install that would be great.
Bill
Graphite 2013 "Altitude" with an expanding wishlist.
Would I be right in guessing the power lead is a standard 'small' USB connector and that you can plug the Blackvue directly into a PC with a USB lead? The reason I ask is that is what my current dashcam power supply is like. I have modified the one from my existing dashcam so that it is directly wired into power in my roof console - it's currently connected to the switched main battery power but all I have to do is move one wire and it will be connected to the permanent aux battery power. This will make installation even easier than I thought
Oh well, it was worth a try. That raises another question though - I thought you were able to connect it to a PC and use the software they provide on the PC - is this not the case?
Another question, can you download the video through the WiFi or do you have to unplug the memory card and copy it direct from there (like I do on my existing one)?
You can't connect the camera directly to the PC. You use the microSD card. The software automatically points to the card location when connected but you can change the location if you want eg you've downloaded the files to another location.
You can connect via wifi, but it seems rather slow. Not sure what the range is either.
1. Connect to the Blackvue WiFi network.
2. Type "ftp://191.168.8.1/Blackvue/Record/" into your browser (It is ftp: not http You will see all the files there.
