recovery points
    Re: recovery points
    Originally posted by Danrex
    Hi Michael,
    Just had a look at mine (factory bullbar as well) which look similar to yours except mine seams to be cut off at the bottom (orange line down) and two holes drilled. And the recovery hooks bolted on sideways. I think your right about how they may not fit on your setup??
    They'll fit, I think you'll find you just need to remove the tie down points in their entirety. Bolting the hooks sideways onto the tie down point as you have is actually creating a weak point and potentially dangerous. Recovery points should be mounted to the chasis for safety and strength.
    [b]2000 Prado RV6[/b] ~ TJM Type 15 Steel Bullbar ~ Uniden 400SX-RM & GME4702 Ant ~ Front Tow/Recovery Hooks ~ ARB Recovery Kit ~ ARB CKMP12 Air Compressor ~ DIY Rear Door Trim & Table ~ Extended Diff Breathers ~ Safari Snorkel ~ Wireless Reverse Camera ~ Iron Ox Full Length Roof Rack ~ Looong Wish List ...
      Re: recovery points
      RogueAussie
      You can't remove the tie down points as they are part of the bracket that holds on the Bull Bar
      Michael
      Michael
      [b]2001 Prado GXL 3.4l [/b]: Toyota alloy bullbar ; Toyota tow bar; Bushranger recovery hitch; Mickey Thompson AZT 4-Rib; Mega Grunt compressor; ARB speedy seal kit; Safari Snorkel; Tough Dog 2" lift kit, Uniden UH015sx UHF; Reversing Camera;
        Re: recovery points
        Hi Michael and RogueAussie,
        You now have me scatching my head. Cant seem to picture how they would sit (bushranger recovery hooks). Would like to see pics of the out come.
        Your right its not ideal where mine are fitted but this is where a 4wd shop told me(mmm!??!!). Especially for the use of a bridal (will pull those two points inwards)!
        Dan
        Danrex
          Re: recovery points
          This is interesting, looks like we have at least three different methods of fitting the factory bull bar. Heres a picture of mine, as you can see the recovery hooks are bolted directly onto the chassis rail and they point downwards.
          Mine is the three litre turbo diesel - which might explain some of the difference :?: Actually, your bar looks slightly different to mine as well :?:
            Re: recovery points
            Your hook appear to be bolt on the same as mine Rainman. I am running a TJM bar.
              Re: recovery points
              Looks like I have to find another solution. My bar set up is the same as Michael's. Is there anybody else with recovery hooks on a factory bulbar set up?
              Danrex
                Re: recovery points
                Ok, here are the pics of my hooks. Took the photos and still forgot to measure the bolt seperation dammit :P
                  Re: recovery points
                  Hi Guys,
                  pretty interesting reading, I have beeing trying to figure out how to fit Bushranger hooks to my front end, as my tie downs and bull bar are identical to Michaels, The do almost look solid enough to use in a recovery, but was always more keen to purchase some propper rated ones.....
                  is looks like our only option is to either replace the bar or do a cut job on the bracket.......
                  Not a fan of cutting, and cant afford a steel bar at this stage :cry: ...
                  Ghost
                    Re: recovery points
                    All you guys with the Factory Bars, might I suggest one of you (if not all of you, for effect) email Lukey and ask if he has something to suit. If you supply a photo I'm sure it would help. If he makes the 2 bolt model that I am chasing then I'd say that might fit on there without removing or altering the factory point ... just a suggestion.
                      Re: recovery points
                      Hey Rouge,
                      Sounds like a plan mate, I'm keen for that, how about you other lads???
                      Cheers Ghost
                        Re: recovery points
                        Hi All,
                        It has been an interesting read this thread :!:
                        I have the same style of factory bar with the same mounting brackets, back in 2008 I did a short trip across the Simpson and beyond 8).
                        As the trip was approved by the Scouts certain requirements were to be met and you guessed it .. recovery points were one of them.
                        So I visited ARB, TJM the local 4 wd specialists (Fourby's), I had the official Off Road Driving instructor inspect my Prado ( who also builds and competes in off road competion himself), plus a couple of very experienced off roaders who also happen to be mining and mechanical engineers and the answer .... just use the ones already there .
                        Myself, I'm a mechanic although off the tools for the last 5 years but that supported my own thoughts.
                        Yes I know they are not "rated" but looking at the structure as long as the welding has been done by a certified welder ( and as these are Factory approved and fitted quality should be good) should not be an issue.
                        To be extra careful I use a long bridle to ensure as much force as possible is applied in line with the chassis rails.
                        Yes rated should be better but having seen last year in Cape York a Rated recovery point pulled out of a chassis rail :shock: on a 18 month old vehicle there is more to it than just the recovery point itself.
                        So my thoughts are use the existing points with a bridle & leash, plus always dig first etc to minimise stresses where you can.
                        Lee
                        edit, as my bar is Airbag compliant I believe that is part of the reason for the design of the bullbar mounting bracket, I assume your bars are as well?
                          Re: recovery points
                          Yep be interested in a Lukey solution!
                          I dont have the loops like you guys just two holes like it was made for a recovery hook to be attached! ( hmmm NOT!)
                          If no solution, cause the loops or hooks would have to hang down lower past the brackets, might do a bit of cutting!
                          Danrex
                          • #28
                            Re: recovery points
                            Hi Leethal,
                            Thanks for that info mate, atleast we ( as on the guys that have the same set up an myself) may be able to get away with using the current units.
                            Cheers Ghost
                            • #29
                              Re: recovery points
                              Hey guys, happen to catch up with my hunting buddy today, he used to work with ARB, he had a gander at my two recovery points and did say that would be plenty strong enough for recovery, he has them on his hilux and uses them as his recovery point
                              Cheers Ghost
                              • #30
                                Re: recovery points
                                It's amazing the information that comes to hand when you stir up a bit of discussion. Good to see people contributing to a great forum!
