Matt's 150 GXL
  • Not really MK. Maybe if the fridge was smaller.
    [CENTER][B][U]Matt
    [/CENTER]
    [SIZE=2]
    [/SIZE][CENTER][SIZE=2]
    [/SIZE][/CENTER]
    • Rear door LED
      Wired in a small LED light into the back door, to see into my Drifta and the fridge at night. It's hard wired to the fuse block in the back and is supplied by the aux battery.
      [CENTER][B][U]Matt
      [/CENTER]
      [SIZE=2]
      [/SIZE][/CENTER]
      • Camper shakedown
        Got the camper out of hibernation today. Set it up and double checked everything. Started making a push bike holder for the front drawbar as well.
        [CENTER][B][U]Matt
        [/CENTER]
        [SIZE=2]
        [/SIZE][/CENTER]
        • Originally posted by Matt - mr4x4 View Post
          First Clarkson, now Matt. Is there an end to the cyclists coming out of the cupboards?
          • Like the rubber mat idea on top of the draws Matt, would also stop the crap sliding around in the back.
            Daniel
            • Originally posted by Rogerthatv2 View Post
              Spot on. Works great !
              No. My kids pushies.. Not mine
              [CENTER][B][U]Matt
              [/CENTER]
              [SIZE=2]
              [/SIZE][/CENTER]
              • I need lights in the back and out the back. Damn. Good work Matt chan.
                • Bought a killer led headlamp off fleabay. Tried it out tonight and it is a winner. Will give it a great run on my Straddie trip next month..
                  [CENTER][B][U]Matt
                  [/CENTER]
                  [SIZE=2]
                  [/SIZE][/CENTER]
                  • Matt is that a Fenix? I read and hear good things.
                    • Yeah Fenix it is !
                      [CENTER][B][U]Matt
                      [/CENTER]
                      [SIZE=2]
                      [/SIZE][/CENTER]
                      • I have had a wriggly noise in the front of the inner guard. I dropped out the second battery and the headlight looking for cracks in the inner guards. The noise was whenever I drove over small bumps the noise would appear. Finally I found that when ARB fitted the bullbar, as the inner plastic guards were trimmed to fit, the just jammed a part of the guard up against the wing of the bullbar. Once I trimmed the guard and refitted everything, my test drive proved no more bloody noises !
                        ARB need to start to think more about what they do..
                        [CENTER][B][U]Matt
                        [/CENTER]
                        [SIZE=2]
                        [/SIZE][/CENTER]
                        • Gave the Prado a good wash and clean up this arvo. Hope to give the duco a polish up next weekend..
                          Came up ok.
                          [CENTER][B][U]Matt
                          [/CENTER]
                          [SIZE=2]
                          [/SIZE][/CENTER]
                            Had a decent run this arvo on the light for the awning. I followed a install guide I found in Pradopoint from a few months ago. Tomorrow I need to hard wire everything to the switch inside the cargo area. The wiring up behind the tail light was 'fun' to say the bloody least... I have set it up, so you just click the Deutsch connector together when you need power to the awning, when its not being used you just tuck it away. This saves having to drill into the frame of the awning and eliminates any chance of water getting into the awning.
                            Matt whats size cable did you use?
                            Robert
                            [B]Robert
                            • [QUOTE=Matt - mr4x4;410167]Just sorted out a pair of Monster Rides progressive bumpstops from Matt at Monster Rides. Over at newhilux.net the lads are mighty impressed with increase in control at full compression when the front end bottoms out, off road. For the money, I'm keen to swap out the stock stops for these and try them out. I will report how they go.. Pics from newhilux.net fitted to a hilux /QUOTE]
                              Matt, how are these going?
                              I have since heard of a few failures of these on FJs at full compression as they are fairly soft.
                              Have they been ok on your prado ?
                              Cheers Robert
                              [B]Robert
                              • Hi Gumboot.
                                From memory the cable is just 4mm twin core from Auto One. My bumpstops are performing great, no issues at all.
                                I inspected them today while I was sorting out the noise in the front end.
                                [CENTER][B][U]Matt
                                [/CENTER]
                                [SIZE=2]
                                [/SIZE][/CENTER]
