I tried to take photos but didn't work out, basically its run down the right gutter then under the rear door seal so you don't even know its there, i'll do some more photos this arvo and see if they are any better.
Also the switch to turn the lights on are on the rear door when we are parked up for camping purposes, but they still turn on when put in reverse.
Cheers Derek
Cheers for that Derek. Some more photos would be great.
Will look into wiring them the same way. Was it difficult?
Just fitted the high beam HID lights and pretty impressed with the output, they are 55w in 4300k light, trying to upload photos but having trouble.
Took about 15 minutes to fit and had to take the second battery out for access.
Cheers Derek
I've just been to Oppy Lock and ordered an E-locker for the rear end as well as 4 x max-trax in blue, like I said ching ching, getting close to having the beast how I want it
Any thoughts on re-gearing at the same time as installing the locker or are you finding power and drive-ability ok with the bigger tyres?
Don't have any problems with the drive-ability at the moment, so no need to re-gear, a bit more power is needed and when I get the exhaust done see where I go from there, not too keen on chipping the engine so probably won't do that.
Cheers Derek
Derek,
Interested to see what you do exhaust wise and who you get to do it in Darwin.
2012 GXL White Prado. TJM BUllbar, TJM Winch, TJM Side Steps and Bush Bars, Black Widow Drawers, MSA Fridge Drop Slide, TJM Dual Battery Setup with Optima Battery, TJM Snorkel, Black Widow Roof Rack with Fred's Arm & TJM Awning, GME 3340 UHF, HID Drivivng Lights, TJM full underbody protection, Morosso Oil catch can, MSA Canvas Seat Covers, Kaymar Rear Bar with Dual Wheel Carriers. Cooper STMax tyres on original rims.Scanguage II.
Awesome build up Derek, it's becoming quite a machine! How do you find the reverse lights? I'm thinking of doing something similar and also on the passenger side to light up under the awning. Would they be too bright for general lighting while camping?
Cheers JPH
150 with stuff bolted on!
Cheers JPH
Hi JPH,
they are bright, and are probably too bright for under a awning but out behind the rig they light up a large area like daylight, under the awning it would be better with LED strips with a switch to adjust the intensity to suit your purposes, this is what I'm going to do under our awning.
Cheers Derek
Cheers Derek
Hmmm, did wonder, I might even try some single LEDs, good stuff!
Home tomorrow, been a long 2 weeks, test out the e-locker somewhere and also got the V8s happening, XXXX angels, Races, booze here i come
Reason: added large picture
Personally I think that colour is over rated. Ooops. Underrated. Looks great. Whats the plan for sliders/steps since it looks as though the papier mache factory ones are still on the beastie?
still looking for sliders, the paper mache ones do look out of place on the beast but Helga needs them to get in otherwise I would take them off.
