two + Four's 2008 GXL
  • #31
    Re: 2008 GXL
    Finally for Christmas this year the Prado got some Nane spotties. Here is the three versions of the lights
    Cheers all, I hope you have all had a great Christmas and have an even better new year
    Neil
    White 2013 GXL 79 series dual cab, ARB GVM Upgrade, ARB Delux winch bar and scrub bars, GME TX3440 and much more to come
    • #32
      Re: two + Four's 2008 GXL
      Not really part of the rig, but part of the camping gear. We camp often and had considered a camping trailer but it the end opted for a couple of 30 second tents for the flexibility (on the garden trailer or the roof depending on our plans). Anyway when camping with the trailer we like a little luxury and tend to set up a pretty full on campsite. Over Christmas we picked up an old double stainless steel sink so come Easter rather than going away when every one else does Pam and I knocked up camping kitchen (nicknamed the coffin)
      Closed on a bunnings table with shortened legs and plumbed holes
      Opened with the contents on display
      Plumbing connected
      Plumbing disconnected and on display
      Cheers Neil
      • #33
        classic mate!!!
        well done ..
        cheers Joey
        -issue 52 Modified 4wds .
        • #34
          Nice looking sink setup Neil, you must have a lot of dishes to do when you go camping. :lol:
          Travelling Panelbeater
          • #35
            Got the fridge slide a few months ago (thanks Leachy) finally got round to some pics.
            Fridge out
            Fridge in
            Neil
            • #36
              Ok a couple more mods done
              Added a TPO9X1 from digi-options
              I have set it up so if it plays a DVD it can be displayed on the kids units in the back. Also using the Aux i/p if the kids play something it can be watch on the TP head unit.
              Running iGO and Ozi explorer CE on it.
              Also added a number plate replacement light rear view camera
              And finally a LCD dual battery monitor that looks like an analogue meter
              From Autron http://www.autron.com.au/newweb/index1280.htm
              Cheers Neil
              • #37
                Hey Neil,
                Shame I missed out on doing the install with you. I will have to organise another time to do mine when you are free. Looks like your running out of things to add to the Prado (if there ever was such a problem)
                Papo.
                • #38
                  Originally posted by Papo
                  Hey Neil,
                  Papo.
                  run out never....
                  Next will be the tyres, hopefully sooner rather than later.
                  I will need some sort of spacer for the spare (tempted by the Kaymar offering because I want a work light)
                  Then I will extend the breathers (already have the kit)
                  Need to run an earth cable for the Fridge power point rather than use the chassis
                  Need to run a power point for the kids DVD player so there is one less lead in the front
                  Anderson plugs
                  sliders
                  then there is the long term stuff...
                  John I will PM you with a time I think I am busy the next two weekends
                  Cheers Neil
                  • #39
                    Ok a few new add ons
                    first a rear wheel spacer and rear arb awning
                    and finally some new shoes
                    Mickey Thompson ATZ 4 rib
                    • #40
                      Installed my Worklight Kaymar mount (External switch) with Ebay 5x3 watt cree LED lamp
                      Had a spare switch so installed that inside (Bottom left)
                      Hopefully get the breathers done before I go back to work.
                      • #41
                        hi i am looking at doing the rear light and just want to know how you wired it up do u have to drill a hole in the back door to pass the wire through
                        thanks ryan
                        08 GXL D4D Auto, BFG A/T
                        • #42
                          Hi Ryan,
                          no holes in the back door. Originally I ran one wire for the switch and the lamp, but I blew the fuse a couple of times so I added a second wire and a relay.
                          Basically the two wires are wrapped with self amalgamating tape at various parts along their length and tucked under the window. They then go into some conduit to protect them from the hinge and down to the goose neck.
                          Wires: Lamp mount to Window
                          Wires: tucked under window
                          Conduit
                          Cheers Neil
                          • #43
                            Seeing this rig on Friday after Niel picked up the cargo cage, gave me some new inspiration of what mine can become ahhaha... Tax time has been put aside for a lift kit and dual battery install if things go well. WooHoot!
                            • #44
                              This is turning into a mighty fine 120 !!
                              I am impressed.
                              [CENTER][B][U]Matt
                              [/CENTER]
                              [SIZE=2]
                              [/SIZE][CENTER][SIZE=2]
                              [/SIZE][/CENTER]
                              • #45
                                I am impressed.
                                Thanks Matt
                                I love the way you have drilled out the bolt to feed your power cable through for your worklight.
                                Neil
