yeah for dramas of getting to the oil filter with the bash plate on its not worth the hassle for six bolts!
Glen's 95 series Prado getting broken in
Last edited by glen_ep; 01-04-2020, 02:16 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Last edited by glen_ep; 01-04-2020, 02:15 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Is that long bash plate, running back to the rear diff, stock in Australia? Or is it a tank guard (we don't have a tank fitted there on the UK models)?Last edited by fridayman; 23-07-2012, 05:43 AM.95 3.0 Camp Car, 150 V6 Daily Driver[SIZE=4]
[/SIZE]
Nice work. I think what's equally impressive, is how clean your undercarriage is, considering where your rig has beenOriginally posted by glen_ep View Post
Do you have any photos of the bash plate installed?Last edited by williade; 23-07-2012, 10:18 AM.[B]Declan[/B]: [SIZE=1]1997 GXL 4.5 Auto 80 series on [B][COLOR="#FF0000"]LPG[/COLOR][/B], ARB bullbar, 2" OME lift, 32" MTZ, GME UHF, rear ARB locker, Kaymar spare wheel carrier[/SIZE]
Yeah it's a tank guard for the auxiliary tank. It's stock in almost all Australian models. Unfortunately it's taking up a lot of my clearance and copping a good beatingOriginally posted by fridayman View PostIs that long bash plate, running back to the rear diff, stock in Australia? Or is it a tank guard (we don't have a tank fitted there on the UK models)?
Originally posted by williade View PostNice work. I think what's equally impressive, is how clean your undercarriage is, considering where your rig has been
haha thanks! I do clean it you know :P Particularly underneath.
Oh, no fitted photos of the front plate yet, I'll get one - but FYI, it's already been dented !glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Dented 4mm Steel? Nice. Glad you have it?Originally posted by glen_ep View PostOh, no fitted photos of the front plate yet, I'll get one - but FYI, it's already been dented !
BTW, those chassis welds that Lukey did look superb.
OT: I wonder if Toyota lower trailing arm mounts are actually lower than those on GQ/GU Patrols or if the Toyota chassis rails are higher, giving the illusion of low hanging mounts
Ah, glad? Yeah! I dropped off a step which much bigger than expected, the stockers would have been stuffed, if not even something else...Originally posted by williade View PostDented 4mm Steel? Nice. Glad you have it?
Yes, looks like some nice welding, and I'm glad he choose round tube - as curved welds are safer/stronger than straight lines.
I'll try to get a bash plate pic up today.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Last edited by glen_ep; 01-04-2020, 02:14 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Thanks Max! I can't take credit for all the work though, I get the welding done by professionals
(one of which is a friend)
Nah the bash plate was originally from Maxquarie 4x4. I bought it off Declan when he sold his PradoOriginally posted by Talktheroo View PostHa Glen, was that bash plate a Brown Davis before it became a Glen Special Bash plate, or did you make that little ripper up from scratch? Mate, I reckon your rig is up for being photographed by EMG (4WD Action) for an article. It's a hell rig that one of yours and you just have to come up with a solution for those bloody CVs. Have you contacted Driveline Services there yet? Did you end up putting a diff lock in the front after the pinions got damaged? How do you feel about putting a hot weld to that chassis of yours?
Sorry, this is a little off subject but Glen does some interesting mods.
John (##########).
Here's their website:
http://www.macquarie4x4.com.au/index...=Bash%20Plates
If I'm contacted for publishing I'd probably go along with it... but I wont settle for photos on fire trails and splashing though mud puddles; they'll have to be on rocks!!
The last CV was replaced under warranty so I'm not too worried
I probably won't look for stronger ones, because it's nice to know where the weak spot is. I always take a spare CV shaft on day trips and the right tools, so can change it myself. If I have stronger CV's, I fear that the transfer will be next. It's unlikely to be diffs, because they're both strengthened by diff lockers.
What do you mean by hot weld on the chassis? It's had a couple small welds already.Last edited by glen_ep; 25-07-2012, 06:56 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
That`s a very very good job on both mods!!!!
Glen, what do you think about this:
http://toyteclifts.com/index.php?pag...mart&Itemid=72
CheersPrado RZJ90. OME 881 coils Nitrocharger Sport shocks front, 80 Series front coils & rear 80 series Tokico shocks rear, 255/85R16 Cooper Discoverer ST, Viper rocksliders, parking brake cable rear axle bracket, extended rear brake line, extended diff breathers, headers, engine perfomance mods, soon LR upper control arms, ARB rear locker in the future.
