Interesting. I will certainly have a play in May in the Simpson. No Scan gauge on the horizon as I was given a EDS-engine data scan and as far as I can work out it can't be programmed for transmission info.
Simpson Desert Crossing 2018 🐪
Even in low range my converter will hit 110 degrees constantly on a warm day in the high country. It's a struggle to keep it under 115 and that's with a cooler.
I wouldn't think you'd have that issue in the desert though as the dunes are short and you'll spend most of your time cruising on the flat.
- 1 like
Yikes! Ive not seen mine above 90 deg C, and thats even after climbing Billy Goats on a 30 deg C day.
Originally posted by RBJET View PostEven in low range my converter will hit 110 degrees constantly on a warm day in the high country. It's a struggle to keep it under 115 and that's with a cooler.
Originally posted by Sefo View PostLow Range and hit the 2nd Start button. it then skips 1st gear altogether. You can manually go down to 1st if you need it. Use it all the time 4wding.2018 GXL D4D auto, ARB bar, dual batteries, BFG A/T's, Dobinson/Bilstein suspension
Sleeky5: I agree. Desert dune driving IS different to driving on places like Fraser Island, The High Country etc. Essentially the work is done in very short bursts going UP dunes - high 1st is fine if your tyre pressures are right. Down the the dunes and between the dunes drive it like a manual and select the appropriate gear so neither engine nor gearbox is being flogged. In the desert, treat them gently and you have less chance of breaking things.
All very good tips so far, thanks everyone! I also previously plumbed in a PWR oil cooler after the factory auto tranny oil cooler, removing the radiator cooling section. I have a scan gauge 2 fitted, yet can’t figure out how to have it read the tranny temp, at the moment it just reads the engine radiator temp.04' 120 PRADO GXL 4ltr Petrol V6 4mm bushskinz steel bashplate 8Tonne recovery points Ironman 4x4 Snorkel 2” lift and other bits of fruit, ready for the next adventure
Not bad for an old girl, got her in for a health check tomorrow. Gives me plenty of time to get any major issues sorted before the big trip.04' 120 PRADO GXL 4ltr Petrol V6 4mm bushskinz steel bashplate 8Tonne recovery points Ironman 4x4 Snorkel 2” lift and other bits of fruit, ready for the next adventure
Health check done, need to re-book to get the front drive shaft seals replaced, when they do that they’ll replace the front diff oil, they found a massive crack on the right hand side exhaust header, which I could hear, didn’t realise how bad it was until they pointed it out to me, so I’m up for a set of new extractors... Tie rod ends got replaced, front tyres were scrubbing out a bit much, so hopefully they did a good wheel alignment..!04' 120 PRADO GXL 4ltr Petrol V6 4mm bushskinz steel bashplate 8Tonne recovery points Ironman 4x4 Snorkel 2” lift and other bits of fruit, ready for the next adventure
some great advise and good debate on different points of views , im more an island off roader but i will eventually get to the simpson . thanks for all the great tips. i would love to hear about the difficulties of the trip from some that are planning and from those that have already done the trip.
it would be good to know what is really needed to bring , and how much time from brisbane would be comfortable to return . do most of you cross the dessert and return another route?
Does anyone know what the code is on the scan gauge 2 to enable the reading of the transmission oil temperature? It only reads radiator temp at the moment.04' 120 PRADO GXL 4ltr Petrol V6 4mm bushskinz steel bashplate 8Tonne recovery points Ironman 4x4 Snorkel 2” lift and other bits of fruit, ready for the next adventure
Once you have done Birdsville to Mt Dare, you had just as well go to Lambert's center of Aust, Chambers Piller, Alice Springs, Rainbow Valley, Kings Canyon, Ayers Rock, The Olgas, The Painted Desert, The Oodnadatta track, back through Wilpaena Pound, Broken Hill and back home. Well that's what we did anyway.Greg - 08 D4D Prado,
- 1 like
