The one I got was a horn micro relay http://www.jaycar.com.au/productView.asp?ID=SY4045
Useful Wire Colors and locations
Hi all, I am going to fit an engine saver this weekend. Does anyone know of an ACC live wire on the interior drivers side?
Alan[color=#0000BF](The MK II) 2012 GXL Auto Diesel, White, ARB Bull Bar, Warn 9500lb XDC Winch, ARB Alloy Roof Rack, Aussieoutdoordirect Awning, Toyota Tow Bar, Safari Snorkel, ORS Rear Drawers and Fridge Slide, ARB Battery System with REDARC isolator, ERPS 10 Pad electronic Rust Cont, 275/65/17 BFG AT's, Jumbuck Sheep Skin Seat Covers, REDARC EBRH Brake Controller, OME 2" lift kit, Air Bag Man high pressure air bags, ARB CKMA12 on board compressor.[/color]
Front or back? There are some on switches like the electric mirror control, 12V socket or the pretty green wire in the back near the inverter.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Maybe, I am only going on what has been posted here or the 120 equivalent. I haven't tapped into power there yet.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Front, under dash drivers side.Originally posted by mjrandom View PostFront or back? There are some on switches like the electric mirror control, 12V socket or the pretty green wire in the back near the inverter.[color=#0000BF](The MK II) 2012 GXL Auto Diesel, White, ARB Bull Bar, Warn 9500lb XDC Winch, ARB Alloy Roof Rack, Aussieoutdoordirect Awning, Toyota Tow Bar, Safari Snorkel, ORS Rear Drawers and Fridge Slide, ARB Battery System with REDARC isolator, ERPS 10 Pad electronic Rust Cont, 275/65/17 BFG AT's, Jumbuck Sheep Skin Seat Covers, REDARC EBRH Brake Controller, OME 2" lift kit, Air Bag Man high pressure air bags, ARB CKMA12 on board compressor.[/color]
Thanx for the advice mjrandom, for anyone else looking for an easy acc power pickup under the drivers side dash the PINK wire on the electric mirror control is the go.
Hi Alan, as I posted above, I am wondering whether power to the mirrors is cut once you reach a certain speed as the mirrors cannot be adjusted unless you are moving quite slow. I have no idea how Toyota do this (I am guessing through the body computer) however I reckon it would be worth testing.
Cheers..............WayneWhite 2012 GXL 150 TD Auto. Work in progress. Aiming to spend less than when I kitted out the 120!
Not on my 150. I have adjusted the mirrors at 100kph when checking the back tyres on dirt/rock roads.Originally posted by hulbyw View PostHi Alan, as I posted above, I am wondering whether power to the mirrors is cut once you reach a certain speed as the mirrors cannot be adjusted unless you are moving quite slow. I have no idea how Toyota do this (I am guessing through the body computer) however I reckon it would be worth testing.
Prone2018 Prado 150 VX Auto
Read this at lunch time today so tested on my way home. Mirrors worked at 110kph and even the fold button worked. Mine is a 2012 GXL.Originally posted by hulbyw View PostHi Alan, as I posted above, I am wondering whether power to the mirrors is cut once you reach a certain speed as the mirrors cannot be adjusted unless you are moving quite slow. I have no idea how Toyota do this (I am guessing through the body computer) however I reckon it would be worth testing.
Does anyone know if there is a hi beam wire and colour of the wire on the passenger side, that I can uses as a trigger wire?Originally posted by advntur2010 View Poston the back of your hi beam on the drivers side there is the green with black tracer that you can tap into as a trigger wire for your spotlightsGraphite 2013 "Altitude" with an expanding wishlist.
Are you asking inside the cabin or at the light?Originally posted by Wagon Man View PostDoes anyone know if there is a hi beam wire and colour of the wire on the passenger side, that I can uses as a trigger wire?My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
