For those that have done it - How difficult is it to set up a bootcamp partition with Win7 on a MacBook Pro? Do you need a legit copy of Win7?
Working eBay Techstream
Done it. Works fine. Just the usual effort to install an operating system. Google it, bootcamp is not rocket science. You need a copy of Win7, which you are asked to register each time you boot up.Originally posted by rorza View PostFor those that have done it - How difficult is it to set up a bootcamp partition with Win7 on a MacBook Pro? Do you need a legit copy of Win7?2010 Kakadu. TJM T13 bar, TJM 9500lb winch, FJ Cruiser 17" rims with 265/70R17 Coopers S/T maxx, 40mm lift, Dobinson's C59-726, Bilstein shocks, Airtek snorkel, Recovery points, Brown Davies bash plates, TG150 transfer case guard. Rhino Pioneer Platform SuperPeg Rear Awning. Drifta Drawer System, Cargobarrier. Optima dual battery. GME UHF, Sandgrabbas.. ARB 47l fridge freezer.
Hi all
So while waiting for my VCI cable to arrive I want to set up my PC. I am going to use an older Win 7 machine I have lying around.
Is there a licensed version of the latest 9.30.029 software around ?
I could get if from this site below but I am guessing a license key would be required ?
http://www.toyota-tech.eu/GTS/Wizard...-Software.aspxLast edited by ozwapet2; 09-01-2015, 12:01 PM.Cheers, Wayne
http://www.ebay.com.au/itm/V9-30-029...item3397594afaHas anyone used this on from ebay. It says it will run 32 or 64 pit
I would be a little wary, states cable will work with 64bit system, well seeing it's a USB
interface I would hope it would!
It doesn't actually state that the supplied software is 64Bit though.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
I don't think the Mini VCI cable itself would be much different. They would have to have developed a new MVCI driver. Would be interesting for someone to buy from that vendor and see what you get for the extra $20 or so.
I just got one working that I bought from another e-bay Chinese seller. If you go through the process of manually installing the driver and changing the registry as explained in this thread it works fine.
http://www.toyota-4runner.org/genera...-8-64-bit.html
I did not use any of the software that came on the disk. I just downloaded a later version of Techstream from one of the many sites that have it.
You can see some of the screenshots from my first reading on my thread here
http://www.pradopoint.com/showthread...njectors/page2
You just have to follow the set up process methodically - try to take shortcuts and it probably won't work.
Probably best not to do it on a machine that is important for other things. I had an older Dell laptop that has become my experimental machine so I set it up on that.Last edited by ozwapet2; 15-01-2015, 11:17 AM.Cheers, Wayne
I sent this to the seller.
Hi,I notice that your description says that the cable supports 64 bit system and that it supports the latest version of Techstream, however it does not specifically state the the supplied software is the lasest version of Techstream or the it is 64 bit compatible. Could your provide this information please as I have been misslead by ebay descriptions before. Not saying you are doing this just want to be sure. Thanks.-
And received this. I think I will buy one and see how it goes.
Hi friend, this mini vci cable comes with a software cd which contains the techstream v9.20.029 software, the software supports both 32bit and 64bit systems,any other questions please feel free to ask.Thanksobdfamily
Hmm, well I don't think the Techstream software itself was the problem, and you can download the latest software yourself.Originally posted by Mozz View PostI sent this to the seller.
The issue, as I understand it, is that an XHorse driver is used, because these cables are rip offs off a product developed by XHorse.
The XHorse drivers previously used and distributed did not install correctly on 64 bit systems.
Be interesting to see how you go.Last edited by ozwapet2; 15-01-2015, 01:35 PM.Cheers, Wayne
Does anyone on the Sunshine Coast have techstream? I bought a cable and installed the program tonight however when I click connect to vehicle the computer is not communicating with the cable. The green light is on but it no workies. Just wondering if I can try someone else's cable or someone try my cable on a computer that is known to work.
Edit: am using a 32bit computer. I tried with my 64bit laptop but could not get the driver to install.
Hi all
I have just ordered the Techstream v9.20.029 "kit" from the supplier that Mozz has mentioned in the thread above. might be a few extra dollars but i didn't want to fiddle with my laptop that I use for work. The receipt indicated early to mid-February delivery. Will keep you posted.
MarkMark
150 Series GXL White T/D auto
[B]2010 GXL Prado D4D Auto[/B] - ARB Deluxe winch bar, Roadsafe recovery points, Rhinorack Pioneer platform, AMTS fuel filter/compressor combo bracket with FM100 filter and ARB compressor, Maxtrax, TIN175 transmission oil cooler bracket and tranny cooler. I'm sure I'll find something else....
+/- 3.0 is danger territory, pretty sure. Not sure about injection volume value though.
#######prado should be along any second now....Last edited by rorza; 25-01-2015, 04:50 PM.
If you do a forum search on "Techstream" a few threads will come up and interpreting the readings is discussed in a few of them.Originally posted by Hollywood View Post
The main one being this
http://www.pradopoint.com/showthread...ght=techstream
You can submit the results to Baileys on their website, they will give a free analysis.
You need to get the cold readings as well.Cheers, Wayne
Thanks Wayne, stumbled across that thread last night. Injector feedback value for number 4 is at the top of the second column of parameters. All looks pretty good so far.[B]2010 GXL Prado D4D Auto[/B] - ARB Deluxe winch bar, Roadsafe recovery points, Rhinorack Pioneer platform, AMTS fuel filter/compressor combo bracket with FM100 filter and ARB compressor, Maxtrax, TIN175 transmission oil cooler bracket and tranny cooler. I'm sure I'll find something else....
Hi everyone
My techstream v9.00.025 kit arrived and I have installed on my Win 7 64 bit laptop. The install seems to work OK. first surprise was when it asked for my dealer name dealer number. Didn't get a chance to try it out this weekend, so will have to try during the week. for those who have set up - do I simply select the menu option "connect to vehicle" and wing it? Is there a user manual that explains things rather than the old trial and error method?
MarkMark
