Working eBay Techstream
  • Just reading this and I am going to get one too. When I go to the ebay links it says something about only doing the 16pin connectors not 22pin.
    Which one do I need for a 2009 120 D4D?
    Can anyone send me the link for the exact one to get please?
    • Originally posted by thebigo View Post
      16 Pin is the one you're after.
      I bought from this mob:
      http://www.ebay.com.au/itm/121288749...84.m1439.l2649
      No issues and arrived in a week. Came with a disc of software but I now the latest version downloaded in the link earlier in this thread.
      Mick
      • Originally posted by OziOffroad View Post
        Mick
        Thanks mate I am ordering now.
        • Got mine running now on my new laptop running Windows 7 64bit with version 9.10.37. all thanks to my youngest son. I new there was a reason I spend about $30K a year keeping him in university.
            Still cheaper than a Windows accredited IT nerd......
            Mick
            • He's supposed to be an IT nerd! That's what he's studying. I reckon he spends most of his time studying the foreign female students.
              • Looking at this for my 1KZ, can anyone tell me what functionality you get on this motor?
                Matt
                • I don't think you can do much other than input the injector codes when you replace them. The device allows me to monitor the feedback values of those pesky injectors before they kill another engine. I look at them every month and have a box full of new injectors and other parts ready to go in. The device also shows all the engine and systems operating parameters like fuel pressure, temperatures, error codes so it's quite useful to see how everything is performing.
                  • I hope someone can answer this please? Not that I am hoping to have to but if the injectors need changing on my 120 can I use techstream to code them in using an ebay cable as above? I bought a VAG cable for my VW a few years ago and it has got me out of trouble several times!
                    • Hey all i really need some help with this. So i got the techstream cable etc but my computer runs windows 7 64 bit. I tried to install a virtual machine but i guess i need to get an operating system to put in it. I really don't want to spend several hundred bucks buying an outdated operating system just to run this program. Does anyone have any solutions (oh and i tried that 'crack' from the american site - followed it step by step and no luck). Is is possible to get a cheap copy of XP anywhere, secondhand?
                      2013 (12 build) GX Auto.......with safari snorkel, toyota bar, tow bar, roof racks, led spots with fancy newpro switchgear, uniden remote UHF and aerial, ARB bash plates, Roadsafe recovery points, digoptions radio, general grabber AT2s, cheap ebay roof rack that has stood up surprisingly well.....
                      • Just Received my TechStream purchased from Here http://www.ebay.com.au/itm/Mini-VCI-...item1c3d5f71ee
                        Followed Instructions from Here for 64bit Install: http://www.ft86club.com/forums/showthread.php?p=1920724
                        MacBook Pro running BootCamp /w Win 7 64bit
                        will run the cold start & after 10min drive Tomorrow
                        I got some messages regarding my L & R rear wheel speed sensors but the scanguage dosnt show anything about them.
                        Will have to look into it further
                        If anyone is on the Sunshine Coast (QLD), feel free to contact me and I can either help setup your cable or do a reading on your vehicle with mine. Otherwise if I make it to a PP G2G ill bring along the gear to do it there
                        HugoStiglitz
                        • Completed my readings. done at idle (cold idle button Off)
                          Vehicle: December 2008 120 Series D4D 1KD-FTV with 135,000k's
                          Injectors: Still Original Factory Fitted
                          Acc On - Coolant Temp ~23 Degrees 0 RPM
                          Injection Volume: 0
                          Inj 1: -1.6
                          Inj 2: 0.7
                          Inj 3: 1.5
                          Inj 4: -1.3
                          Cold Start - Coolant Temp ~31 Degrees - 853 RPM
                          Injection Volume: 12.94 (but it quickly dropped to ~10)
                          Inj 1: -1.1
                          Inj 2: 0.3
                          Inj 3: 1.5
                          Inj 4: -1.3
                          After Short Drive - Coolant Temp ~83 Degrees - 700 RPM
                          Injection Volume 6.60 - 7.0
                          Inj 1: -1.9
                          Inj 2: 0.7
                          Inj 3: 2.3
                          Inj 4: -1.6
                          Looks like I am ok for the moment but Inj 3 looks to be on its way out.
                          I will probably replace all 4 at the 150k service with the timing belt
                          • Anyone else find the application crashing within 10-15 secs of displaying stats?
                            Luckily I had screenshotted the stats before the app died.
                            Win7 x64 Laptop
                            • I'm having the same problem on my Win7 laptop. Pain in the bum. Haven't had time to try different software revisions.
                              • Had same problem, setting laptop for max performance cured it
